Mondial - FD and Spark Plug Wires - questions | FerrariChat
Discussion in 'Mondial' started by aleib, Jan 19, 2023.
  1. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Hi,
    i have two items in one thread, simple ones:
    1) FD has the CO mix screw hole... I could not rotate the screw yet (cant find a long 3mm hex that fits with the correct angle)
    but there should not be a sealing cap there? I put some fuel on it... and entered the FD without issues... so if fuel can get in, air too... so this is a air leak for sure.
    Please confirm.
    2) also, i was swapping spark plug wires, and found the rotor cap and wires are numbered 1-4, but when the wires go to the plugs, they go 1-4 2-3, 3-2 and 4-1.. .inverted... is that ok?
  2. Steve Magnusson
    26,826
    #2 Steve Magnusson, Jan 19, 2023
    Yes -- even a simple rubber stopper would suffice (and you'll probably have to retweak the idle RPM speed and the idle mixture if those were originally set with it missing). This is a typical one (that you should be able to find -- search Volvo and VW parts suppliers):
    Maybe a supplier mismade/mislabeled those spark plug wires -- the cyl #1 wire has to be the longest wire and the cyl # 4 the shortest wire. If it's running well, I wouldn't worry about it.
    ellum likes this.
  3. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    ok BAD to know I had an air leak all this time :(
    the 1-4 labels are in synch with the distributor cap numbers...
    so distributor cap and valve covers are the issue, not the wires itself
  4. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    ok found I took the wrong wire set... both are labeled 1-4 but one is inverted in lengths :)
    why not use 1-8 instead ot two 1-4 labels is a mistery :)
  5. afterburner
    afterburner F1 Rookie
    3,471
    Switzerland
    Urs STEMMLER
  6. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    hhaha well, just purchased the plug, and engine is working better every day... :) thanks for the help
    afterburner likes this.
  7. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    May I ask where you bought the plug? Thanks
  8. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
    Deloreango.com
