Mondial Fuel Injector Questions | FerrariChat
Discussion in 'Technical Q&A' started by FamilyCar, Jan 9, 2014.
  1. FamilyCar
    FamilyCar Formula Junior
    787
    Seattle, Wa
    Peter Goodall
    Hello all--
    I'd like to replace the injectors and seals in my '87 Mondial, but have a few questions I hope someone know the asnwer to:
    1. Is it possible to remove the injector busgh and seals without removing the intake manifold? In the searches I've done it appears they must be pushed out from behind. Is that correct, or has someone figured out how to hook them?
    2. Can the intake manifolds be removed with the engine in the car? It's not clear to me from a quick look if there is adequate clearance to remove either the plenum then the runner assemblies, or maybe the whole unit if possible, either due to access or available height to lift under the edge of the engine cover. I was looking at the Robzworks posts where the motor is clearly in the car, but since that's a 328 I wasn't certain it would work with a Mondial.
    Any insight is appreaciated.
    Thanks,
    Peter
