Mondial Fusebox - location dimensions | FerrariChat
Discussion in 'Mondial' started by Zertec, Apr 9, 2007.
  1. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    Hi Guys,
    I need to know the dimensions (h x w x l) of the largest box that could fit into the space where the fusebox is located in the front of the Mondial. The reason for the question is I am finally sourcing the box needed to house the new fusebox. As the new PCB is a six layer board I am going to add 4 new (spare) high current circuits (with associated relays, connector and fuses) on the spare sixth layer so I will need a little extra area for these items. To keep costs down I am going to use an off the shelf box. So, as I know the area I need for mounting everything, I just need the dimensions of the space so that I can get the most suitable box and adjust the PCB to fit. If any of you lot could take pictures with a rule or measuring tape in shot and give me your best estimates that would be most helpful. I would do it myself but my Mondials don't have the inner pieces in place at present.
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    on my mondi 8 anything bigger than the stock box won't fit, the stock one is a squeeze getting it back in. I can get you dims on the stock one.
  3. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    Thanks for the info Scott. When you have time can you take some pictures of the fusebox in situ please?
