Mondial Heater Valve | FerrariChat
Discussion in 'Mondial' started by Tiganut, Dec 2, 2008.
  1. Tiganut
    Tiganut Karting
    Sep 26, 2005
    154
    Surrey
    Neil
    I understand the Mondial heater valve is sourced from another car,any idea which one?I have tried the search function,but come up with nothing.
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,784
    What flavor of Mondial? 8? QV? 3.2? t?
  3. Tiganut
    Tiganut Karting
    Sep 26, 2005
    154
    Surrey
    Neil
    Its a T,but I thought they all used the same valve.
  4. Steve Magnusson
    26,784
    The QV, 3.2, and t use the same one, but the 8 has a different one.
    Try this thread:
    http://ferrarichat.com/forum/showthread.php?t=84386&highlight=61079000
    Brian B. and Brian K. suggest some other marques that use the same/similar Bosch valve as a t. (Brian B. also gives a good description of how to use a simple 12V bulb to confirm/deny if the electrical drive signals going to the valve are as they should be.)
  5. FamilyCar
    FamilyCar Formula Junior Rossa Subscribed
    Sep 26, 2007
    787
    Seattle, Wa
    Peter Goodall
    For the 3.2 at least, it should be the same as a BMW of the same era. Try this:
    http://www.autohausaz.com/search/product.aspx?sid=gvggrq45yhgpzo55rpdln455&makeid=800003@BMW&modelid=1012341@535I&year=1986&cid=heater%20valve@heater%20valve&gid=6860@AC%20%26%20Heater%20Control%20Valve
    It is rebuildable--if you can get the thing out. I did it in my odler 5-series where ti took all of about 10-minutes. On the Mondial it will probably be 10-minutes as well after the 4-hours it takes to remove the valve for access.
  6. Tiganut
    Tiganut Karting
    Sep 26, 2005
    154
    Surrey
    Neil
    Thanks ,will check that out.
