Mondial High/Low Beam CoNfusIon | FerrariChat
Discussion in 'Mondial' started by rossored, Aug 29, 2007.
  1. rossored
    rossored Rookie
    Jul 18, 2007
    11
    Ok so after searching posts I understand it is not uncommon for a switch to go bad. Here is the short story version. When I switch on the headlights a blue dash light comes on. (Usually I would assume this to signify high beams are on) When you switch into high beams the dash light goes out. Now I switch on the console driving lights and the switch seems to overheat and is stuck in the on position. (which I count myself blessed....this is better than off) My questions: Are the lights wired correctly? Where can I buy a new switch?
    All new to me but hey I used to own Triumphs!
  2. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
    Sounds like (to me, at least) someone reversed the high/low beam wires to the fuse box. High beams will show a blue light on the dash. Low beams will not illuminate the high beam indicator.
    Bob
