News
Mondial Hoses
Discussion in 'Technical Q&A' started by Philjay50, Jun 8, 2004.
  1. Philjay50
    Philjay50 Formula Junior
    Jan 16, 2003
    590
    Chester, England
    Philip
    Has anybody changed the coolant hoses on a Mondial. The engine bay and front radiator looks easy but the pipes that run underneath seem to disappear into a void and I cannot get at the clips.
    The only thing I can think is that you have to disconnect them all and then shuffle the ally pipes back and forth to get the rubber one's on ?
  3. slewman
    slewman Karting
    May 4, 2004
    154
    Remove the coolant pipes at the front and the coolant pipes between the fuel tanks at the rear. Pull the rubber hoses one at a time thru the center chassis tube out towards the front. Coat the new hoses with talcom powder on the outside to prevent binding on install. I have seen these hoses fall apart from the inside and plug radiators.
