MONDIAL PARTS FOR SALE. Please PM me if interested. Thanks...Jim EXTERIOR/BODY -Ferrari fender shields, genuine cloisonné, finest quality reproductions, NEW @ $285/pair (fit Mondial/308/328/348/355/360/430/456/550/575/599/612/California,others) -Right rear quarter panel, NEW @ $500 INTERIOR -Dash windshield vent trims (from 1988 car) @ $100 TOOL/JACK -Ferrari wrench, 9/8mm, “Ferrari, KRAVM” on handle, NEW @ $50 ENGINE/IGNITION -(4) camshafts (from 1982) @ offer -Distributor cap bases, front & rear @ $65 each -Cavis plug wire set @ $100 -Spark plug extenders, 8 @ offer -Emissions equipment for carb car, smog pump (w/upper bracket, heat shield, tube), charcoal canister, vacuum sphere, valves, hoses, air injection rail @ $675/all -Smog pump lower and upper bracket @ $250 -Engine crank shield @ $50 -Cankshaft damper/pulley @ $250 -Rear header, 2 @ $400 ea COOLING Radiator fan (black plastic) @ $50 A/C, HEATER -308 A/C compressor bracket upper @ $100 -308 A/C compressor bracket lower @ $25 -308 A/C dryer, right, includes hoses, temp sensor and t-stat @ $95 -308 A/C dryer, left @ $50 -308 condensor @ $75 -308 heat/AC blower fan motors, (2) for $50 (one is noisy) ELECTRICAL, LIGHTING -308/Mondial OEM Bosch starter, 2 @ $400 ea (no core charge) -308/Mondial OEM Fiat brand starter @ $400 (no core charge) -308/Mondial seat belt relay/ecu (60528200) @ $50 -308/Mondial relay/switch (112198) @ $75 -308 “slow down cyl 1-4” lens @ $10
Updated to include front turn signals... MONDIAL PARTS FOR SALE. Please PM me if interested. Thanks...Jim EXTERIOR/BODY -Ferrari fender shields, genuine cloisonné, finest quality reproductions, NEW @ $285/pair (fit Mondial/308/328/348/355/360/430/456/550/575/599/612/California,others) -Right rear quarter panel, NEW @ $500 INTERIOR -Dash windshield vent trims (from 1988 car) @ $100 TOOL/JACK -Ferrari wrench, 9/8mm, “Ferrari, KRAVM” on handle, NEW @ $50 ENGINE/IGNITION -(4) camshafts (from 1982) @ offer -Distributor cap bases, front & rear @ $65 each -Cavis plug wire set @ $100 -Spark plug extenders, 8 @ offer -Emissions equipment for carb car, smog pump (w/upper bracket, heat shield, tube), charcoal canister, vacuum sphere, valves, hoses, air injection rail @ $675/all -Smog pump lower and upper bracket @ $250 -Engine crank shield @ $50 -Cankshaft damper/pulley @ $250 -Rear header, 2 @ $400 ea COOLING Radiator fan (black plastic) @ $50 A/C, HEATER -308 A/C compressor bracket upper @ $100 -308 A/C compressor bracket lower @ $25 -308 A/C dryer, right, includes hoses, temp sensor and t-stat @ $95 -308 A/C dryer, left @ $50 -308 condensor @ $75 -308 heat/AC blower fan motors, (2) for $50 (one is noisy) ELECTRICAL, LIGHTING -Mondial OEM Bosch starter, 2 @ $400 ea (no core charge) -Mondial OEM Fiat brand starter @ $400 (no core charge) -Mondial seat belt relay/ecu (60528200) @ $50 -Mondial relay/switch (112198) @ $75 -Monidal “slow down cyl 1-4” lens @ $10 -Mondial front turn signal lenses/plastic assemblies, L & R @ $50 ea
Hi Jim, Well it took me 20 months but I found a steering wheel for my '77 308! The stuff I bought from you is going to work out fine, now I'm looking for an Emission Plate in better shape than mine: Image Unavailable, Please Login
Thanks George! I'm glad the pieces worked out Ok. Glad too that you found a steering wheel. I'll keep an eye out for an emissions plate, although I think yours looks pretty good! Best...Jim
Yes, I have Mondial T Cabriolet 1992 and I whish 1 front turn signal lenses/plastic Right color White/Orange !!! If you have the montant RIGHT black rubber for the capote is VERY OK !!! Thanks Carlo
