Mondial Qv brake fluid | FerrariChat
Discussion in 'Mondial' started by racespecferrari, Jul 31, 2006.
  1. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    can someone please tell me how much brake fluid a Mondial Qv takes, I got a 1 Litre bottle of Castrol Srf and see another bottle cheap, just wiondered if I had enough, Thanks Pete
  2. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Pete,
    A 1 liter container should be more than enough to bleed the brakes on the Mondi. It was on mine. Be sure to get as much of the old fluid as you can out of the reservoir before putting the new fluid in, and start bleeding from the right rear. I found it worked best using the "two person" system -- one pumping the brake pedal, one opening/closing the bleeder valve. Just remember to keep the reservoir topped up.
    If you buy an extra container, do not open it unless you are going to be using it right away. You don't want it absorbing any moisture from the air.
  3. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Hi Steve, Thanks for the info, I thought I might have needed a lot as its a longish car, I got the Castrol srf as it has a high boiling point and I have had brake fade several times in the past, its around £40 a litre here in the Uk so I didn't want to buy an extra litre if I didn't need it, I will definitely get two to do the job, Regards Pete
