Mondial QV engine transplantation | Page 3 | FerrariChat
Discussion in 'Mondial' started by stekkefun4, Jun 13, 2016.
  1. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    replaced most of the hoses today. Remember: if you have a hard time attaching a hose over a tube: heat the hose so it gets more flexible.
  2. stekkefun4
    2,232
    Belgium - Europe
    2 days of inactivity thanks to 2 days of Pink Floyd in Tienen !!! Woohooo!!!
  3. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,441
    Belgium
    Jurgen Durand
    Hope Nick Mason would join them again and come in his 250 GTO for you ;)
    best
    Jurgen
  4. stekkefun4
    2,232
    Belgium - Europe
    #54 stekkefun4, Aug 3, 2016
  5. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,441
    Belgium
    Jurgen Durand
    Great job Stefan.
    Putting an 8 into a QV wasn't so obvious, I guess?
    Best
    Jurgen
  6. stekkefun4
    2,232
    Belgium - Europe
    Well, especially the accelerator cable is a point of attention because it is attached to the engine block in a different way, so I was very fortunate I had a spare 8 cable! All the other connections are about the same.
  7. Pero
    Pero Formula Junior
    Apr 22, 2011
    825
    Sweden
    Peter R
    This is really interesting to follow!
    Thanks for sharing!
    /Peter
  8. stekkefun4
    2,232
    Belgium - Europe
    #58 stekkefun4, Aug 9, 2016
    Just installed the refurbished coolant reservoir. Here's how it currently looks like.
    But I have one important question for the Mondial 8 owners:
    If you look at the last picture, there are 2 hoses running from the K-Jetronic warmup regulator: according to the schematics, the hoses should be placed as follows (see schema):
    1. From the top of the regulator to the bottom of the plenum air intake tube
    2. From the right side of the regulator to the top of the plenum air intake tube
    The tubes on my car came the other way round, so my question to you: how is this with your cars? Do these hoses cross one another or do they run in parallel?
  9. enzo360
    enzo360 F1 Veteran
    Aug 1, 2004
    5,441
    Belgium
    Jurgen Durand
    #59 enzo360, Aug 9, 2016
  10. stekkefun4
    2,232
    Belgium - Europe
    So, you have it like on the picture...Thanks for the pic
  11. stekkefun4
    2,232
    Belgium - Europe
    #61 stekkefun4, Aug 10, 2016
    today we tried to start the engine. No success, presumably the interim battary was not powerful enough and the started moved a bit but not enough. Probably also the engine was not lubricated enough by the oil, so we turned the crankshaft manually but even then, no luck. Second attempt is next Monday.
    Then we saw that the pinion inside of the Jetronic was blocked and we had to make it slide again with compressed air, which finally worked and Guido cleaned the pinion and re-installed it.
  12. stekkefun4
    2,232
    Belgium - Europe
    #62 stekkefun4, Aug 10, 2016
  13. stekkefun4
    2,232
    Belgium - Europe
    After 2 big explosions, we finally arrived where the previous owner did: the alternator turns the crankshaft, fuel distribution is OK and a spark is also delivered through the spark plugs, but the engine does not fire up. It looks like the system is out of sync: the spark is delivered at the wrong moment but as far as we can see, the order of the sparks is fine. We ended up 2 with a lot of fuel fumes concentrated in the big tubes with a big BANG when the spark reached the fumes...
  14. stekkefun4
    2,232
    Belgium - Europe
  15. stekkefun4
    2,232
    Belgium - Europe
    #65 stekkefun4, Aug 30, 2016
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,017
    Isle of man- uk
    Have u found the repair kits for the distributor ? I have a link if u need a kit
  17. stekkefun4
    2,232
    Belgium - Europe
    We cleansed the distributor and put it all together again without an issue, so that went well. About the fact that it doesn't fire up: we think this may be caused by the spark distributor cap and coils being out of sync with the order of the cylinders. Fuel runs in them, but the spark doesn't arrive in time.
  18. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Here is an easy one to check, are the TDC sensors from bank 1to4 and 5to8 plugged into their respective Digiplex units and from those the spark goes to the right coils/distributor/bank? If they are crossed over at any point, you may have the explanation for the spark being out of tune,
    cheers
    braq
  19. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,765
    Argent/Brasil
    Guido
    We all checked that. Strange enough we get spark on cil 1 about 15 degrees after TDC...!?with engine NOT running. We cannot find how much it must be for a not running car. WM gives 2 degrees before TDC on 1000 Tr/min.
    Guido
  20. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Sweet work! Ps. There is a 25 euro rebuild kit for the fuel distributor replacing all the rubber o-rings.
  21. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Timing light is an excellent tool for diagnosis by the way.
    Great work though :)
  22. stekkefun4
    2,232
    Belgium - Europe
    Whoppa! Just got a phone call from my mechanic... Good and bad news.
    The 2 flywheel sensors were switched, so the ignition was OK after swapping them.
    The bad news: they found out that the previous owner of the engine encountered a snapped timing belt with the result that some valves are bent! Some cylinders have 0 compression, so next thing is a revision of both cylinder heads...
    So, now I know again what to work for :)
  23. stekkefun4
    2,232
    Belgium - Europe
    #73 stekkefun4, Nov 6, 2016
    Here's the engine of my 'golden' Mondial (you see him standing on jack stands in the back). Tomorrow I'll learn more on what has happened.
  24. theunissenguido
    Jan 21, 2004
    2,765
    Argent/Brasil
    Guido
    Ask the Valenti boys to check if the cames are in the right places....Still think there went something wrong during installation by the pre owner.
    Guido
  25. stekkefun4
    2,232
    Belgium - Europe
    Yes, I was going to do that.
