Mondial QV Ignition light / Alternator light dims when cranking and will not start | FerrariChat
Discussion in 'Mondial' started by Anthony bentley, Mar 5, 2020.
  1. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    560
    London
    Anthony Bentley
    Intermittent problem, Ignition light / Alternator light dims when cranking and will not start. If it doesn't dim it starts. Help.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Multi meter onto the battery and see how far the volts drop when starting, should be min of 10.5 volts
  3. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Tested 10.9 volts.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Better than i was expecting. Sounds like battery is in reasonable nick.
    Have a look at the starter solenoid and see what the resistance is over the terminals.
    Sounds like you are getting 2 different loads when starting, one is pulling the volts down and not starting.
    Starter or its solenoid ? I had a repair kit fitted to my starter motor , no idea if still available
  5. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    The voltage drop seems to be on the spark side with the starter cranking like it should.
  6. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    You could check for 12V @ the ignition modules.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    The key switch should have 2 yellow wires, one goes to the coil supply and the other goes to the ignition module i think, if i remember correct this is in the rear passenger wheel well with a multipin plug. Can send u the wiring dia if you need it
  8. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Yes please, I presume it is something upstream a main feed as it effects both banks, I know it would start and run on one bank if one was ok.
  9. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Where are the main ground straps on the Mondial QV.
    thanks.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Looking at the fuse box, the bottom right relay is for the ignition switch, bosch 0332014113. Is this working.
    Try swap with relay “Q” middle row 4 in from the right. Same relay but for low beams
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Off the battery as far as i know
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Drop me an e mail address for wire diagram
  13. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,668
    Argent/Brasil
    Guido
    #13 theunissenguido, Mar 7, 2020
    Main ground strap is between engine and chassis. Over chassis tubes to negative battery. Dont forget the main switch near the battery. They always gives problems of bad contact. Remove this or put an other that can be put directly on the negative pole.
    Some relais in the WSM and users manual are wrong put on the picture.
    This is how the relais have to be put ;
    https://www.ferrarichat.com/forum/threads/fuseboards-new.582139/page-2 see #29
    For better negative connections you can reed/do this :
    https://www.ferrarichat.com/forum/threads/sticky-mondial-8-qv-3-2-t-repair-thread.209843 see #3
    Guido
  14. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Little update on this, working down chain, earthing out battery, checking battery switch, I have sprayed electrical contact cleaner down the ignition/ key barrel then some WD40 and it starts every time now. I am not sure if this is the fix or not but i’m happy!
    theunissenguido likes this.
