Mondial QV side pod hoses | FerrariChat
Discussion in 'Mondial' started by Paulmendit, May 14, 2025.
  1. Paulmendit
    Paulmendit Rookie
    Feb 26, 2024
    33
    Paul Coles
    The RH side pod on my '84 QV coupe has 3 outlets, the large one at the top goes through to the air filter box, below that is a smaller 45mm dia outlet and below that a 60mm dia outlet. Neither of these lower pair have anything connected to them at the moment and I can't see any mounting clamps for the ducting. From searching the forum it seems that they should have duct pipes attached - which I have sourced for around £15 from Temu (surprisingly good quality corrugated aluminium, painted black on the outside).
    I'm struggling to establish what goes where. I've seen a post which shows the 45mm pipe goes pretty much horizontally across the firewall and feeds cool air to the area around the alternator / front exhaust bank, but I cannot figure out where the 60mm outlet goes - or is the other way round?. From what I've seen it might feed cool air to the rear exhaust bank / fuel injection unit, but I cannot figure out the routing of the duct - well at least not without creating a U bend that would fill up with water!
    Can anyone help?
    Cheers
    Paul
  2. Alden
    Alden F1 Rookie
    3,405
    Central Florida
  3. Paulmendit
    Paulmendit Rookie
    Feb 26, 2024
    33
    Paul Coles
    Alden,
    Thanks for your help so far, I think you're right in that one of the ports goes towards the alternator (probably the 60mm one), and I think the smaller one feeds cool air towards the fuel distributor. I can't see how it would connect to the blow by system - there is a braided hose on the bottom of the air box, but this looks to be an outlet for the crankcase breather hose.
    I'm working on the car today, so will route the ducts as best as I can and see how I get on. The image below - nicked from Maranello Parts shows the three ports
    Paul
  4. Steve Magnusson
    26,627
    I believe that's a bit of a trick question -- they go more to an area rather to a specific thing (i.e., the other end is just left open). On 308 (which only has the larger one), the larger one just generally points at the rear diff housing to cool the hot area between the 1-4 exhaust manifold and the diff like you noted; however, there's a sheetmetal hoop welded to the chassis to hold the free end.
  5. Paulmendit
    Paulmendit Rookie
    Feb 26, 2024
    33
    Paul Coles
    Having removed the wheel arch liner to get a look at the ducting, I found there are 4 ports - there's an additional 45mm dia one high up.
    The large one to the air filter box as expected, the lower pair I've routed flexible hoses to direct air towards the alternator and the space between the exhaust for cylinders 5-8 and the firewall where I guess it must get hot. The port that sits high up feeds air via another flexible hose to the space below the fuel injection unit and above the exhaust for cylinders 1-4.
    Sadly no hoops or clamps were found to guide me, so they are attached with a mix of cable ties and jubilee clips.
