Mondial QV Speedometer Not Working | FerrariChat
Discussion in 'Technical Q&A' started by markqv, Jun 25, 2005.
  1. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Newcastle on Tyne UK
    Mark Neale
    The speedometer has been working fine (albeit it appeared to be a little slow to catch up with the speed of the car when accelerating hard...) and today after starting-up, the needle on the speedometer doesn't move at all.
    Any suggestions?!
  2. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    The usual on a 20 year-old Mondial. Check and clean connections, fuse, relay.
  3. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,498
    Montreal Canada
    Bernie
    Check speedo sensor.
  4. PeterS
    PeterS Five Time F1 World Champ
    51,709
    Goodyear, AZ
    PeterS
    I just bought a new sensor from Lyle Tanner for $160. I was VERY suprised at that price.
  5. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    I am VERY suprised at that price too.
    Dennis McCains has them for $90.
  6. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Mark Neale
    Thanks for the advice.
    I've been through what connections I can identify and have cleaned them - fuses all OK - and presumably a faulty relay would kill more than just the speedometer and everything else appears to be working.
    It looks like the Speedometer itself has been removed in the past as the lugs on the trim bezel have been damaged. May be something here, but as for what to look for...
    I will replace the sender on the gearbox - anyone have the part number? I've been trawling through the offical Ferrari classic parts website and so far I can't find it!
  7. bernardo66
    Dec 14, 2003
    26,498
    Montreal Canada
    Bernie
    197181
  8. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Mark Neale
  9. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Im having exactly the same problem. Replaced the sensor (from Kent High Performance) but still not working. Its taken out the milometer too which isnt a bad thing as I've just done 900 odd mile Le Mans and back. Really appreciate it if you find and cure the problem and let me know!
    Cheers
  10. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Mark Neale
    My odometer is still working, so my money is on the speedometer head being the culprit. I've ordered a new sensor and speedometer (all cheaper than I anticpated at £134.00 plus VAT for the two!) and I will replace the speedometer first before dropping in the new sensor.
    I'll let you know what the outcome is.
  11. f355spider
    f355spider F1 World Champ
    18,038
    Holy crap that is CHEAP! Count yourself lucky.... ;)
  12. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Mark Neale
    The parts were purchased from Ferrari UK - it appears their prices are pretty good for some parts when compared to the 'independents".
  13. markqv
    markqv Rookie
    Apr 29, 2005
    27
    Mark Neale
    Fixed - the speedometer head itself was broken. Easy enough to remove the dial, but getting at the connector buried behind the dash was time consuming and neccessitated a few expletives!
    I now have a spare sender on the shevles ready for when that goes!
