Mondial QV Warning Lights Console | FerrariChat
Discussion in 'Mondial' started by FezzaFella, Oct 7, 2006.
  1. FezzaFella
    FezzaFella Karting
    May 8, 2006
    154
    Can anyone tell me from front to back, the order by colour of the red, white and black connector plus that fit into the side of the warning light console box.
    I lifted mine out when some lights came on that did not correspond with the poblem and found that the wires seems illogical with the set from the front connected to the rear and vice versa.
    Any insight appreciated.
    Andrew
  2. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Give me a little while and I will post a pic
  3. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
  4. Rival
    Rival Formula Junior
    May 12, 2005
    399
    Misipi
    How does that warning console come out of the center console? I tried lifting it out gingerly with a screwdriver, and it didn't budge. Obviously, I don't want to damage it, so please advise me on how it comes out of the console. Thanks.
  5. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    #5 racespecferrari, Oct 7, 2006
  6. Rival
    May 12, 2005
    399
    Misipi
    So it just pulls straight out the top of the console (no screws, etc. holding it in)?
  7. FezzaFella
    FezzaFella Karting
    May 8, 2006
    154
    NF,
    Thanks for your response. Photos are a great help.
    Cheers
    FF
  8. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    #8 racespecferrari, Oct 8, 2006
    Yes it should do, I can't remember if I had actually taken the centre console out and pushed it from the bottom or if I had just pulled it out from the top, either way I remember it being pretty easy.
    If I remember rightly when I had removed the radio I slipped my hand under and pushed it out (see pic)
  9. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    No problem, I am making a photo record of my race project so any help I can give pic wise post and I will supply
    Regards Pete
  10. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    No there aren't any screws etc.., it just spring clipped in
  11. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Rival,
    Be sure that you take off the wire connectors,,, before, you just lift out the warning unit. Spring clips are cool.
    BUT, you will break the unit into a pice of seeet if you DON'T DISCONNECT the clips first. (I see you have complied with
    Guido's plan,,,,, but I just wanted to make this clear to all others with 308s.)
    (This is how they all get broken.) (wink)
  12. Rival
    May 12, 2005
    399
    Misipi
    I don't understand. I just want to lift it out to check bulbs. How can I disconnect the wire connectors before I lift it out?......By the way, this may be all I need to know: when I turn on the headlamps, should anything (background, etc.) light up or should this warning center be completely dark unless it is giving a status / warning?
  13. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    The only way you could disconnect the plugs first is by removing the whole console which is a bugger, there is enough slack in the wiring to pull the warning panel out as the wiring loom comes from the front under the dash and goes past that switch panel to the aircon buttons & window buttons etc..., you can roughly see in the pics I posted
  14. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    At the moment all mine light up. I mean the display not the LED's (apart from one). However mine says it is due a service. When the service light is extinguished (after it has been reset by dealer/specialist etc) then I think just the top half of the warning display lights up. Not sure why or if it is normal. Hope this helps a bit
  15. 350HPMondial
    5,325
    Edwardo
    I never removed the whole console to dissconnect the warning unit. ,,,,, just the Shift Plate, the Ashtray and the cigarette lighter.
    Then you can lift up the side of the console cover and reach under to dissconnect the warning unit. This also gives you access to all of the fiber optic connectors. Check them out now and replace the broken ones.
  16. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Now you stated that, yes I remember I did it via the ashtray, it simply pushed out
