Mondial QV Window Switches | FerrariChat
Discussion in 'Mondial' started by FezzaFella, Jul 30, 2007.
  1. FezzaFella
    FezzaFella Karting
    May 8, 2006
    154
    I did a search but can't find the info I need.
    I need new power window switches for my 83 Mondial QV as the existing "Torrix BteDGSG" model switches have broken. These are the ones that sit on the centre console.
    They seem impossible to find.
    Are they shared by any other car? Fiat? Alfa? DeLorean? Like the 308 Switches were shared by '83-'84 Alfa GTV?
    Can anyone suggest where I might get these?
    Cheers
    FF
  2. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
  3. Dr Tommy Cosgrove
    36,433
    Birmingham, AL
    Tommy
    These are the same as a 308:
    http://www.international-auto.com/index.cfm?fa=p&pid=2556
  4. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    #4 racespecferrari, Aug 1, 2007
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Not sure how you determined they were broken, but all of the center console switched do not work occasionally due to a light layer of contact surface oxidation.
    What I have done in the past with the switches in place:
    1. d/c the battery
    2. spray Radio Shack electrical terminal cleaner spray inside and around the switch
    3. cycle the switch 100x to clean the contact surfaces
    4. let dry 2 hours
    5. reconnect battery
    And they're good to go until next time.
    With yours, You can do the same with them out (I admire you for doing that as I know how tough that is) and try plugging them back in (after they dry!) to see if this could save you a bit.
    Best of luck! We've all been there....
    rt
  6. FezzaFella
    FezzaFella Karting
    May 8, 2006
    154
    NitrousF - do you have any side shots of these as they look different from mine.
    Snj5 - On mine, the metal spring undr the rear side of the rocker switch had broken. I only foundthis when I opened one to see how they worked and if I could re-shape the spring connection to give the switch contact for the window "up 'side. It is a pain getting to them though....
    Thanks for your input. NF - if yours look likethey will fit I will PM you for them.
    FF
  7. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    #7 racespecferrari, Aug 3, 2007
  8. FezzaFella
    FezzaFella Karting
    May 8, 2006
    154
    NF,
    Do you know if the female of the Torrix witch is the same as the female on your Ansor switches?
    How much are you asking for the two?
    FF
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    on the older ones or at least the ones on the M8 they are plastic with a tin trim that can be removed, once removed you can dis-assembly the switch and clean it real good. did mine last yr and fixed the switches, now if it was only as easy for the fuse/relay board.
  10. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Sorry I couldn't tell you on the wiring. I simply unplugged it from the loom before I removed that as well.
    make an offer by Pm if you are interested. Pete
  11. Mike Duncan
    Mike Duncan Rookie
    Aug 11, 2007
    13
    I had a switch leftover from an Alfa spider that worked for one of my rear windows. The markings(arrows) were different. I used the old one to replace a bad glovebox switch!
