Mondial Rear wheel bearings, axle groove nut | FerrariChat
Discussion in 'Mondial' started by theunissenguido, Jun 24, 2010.
  1. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    #1 theunissenguido, Jun 24, 2010
    Hi, Mondialisti
    Changing rear wheel bearings I cannot take of the rear axle groove nut
    I have the right tool from Baum tools
    http://www.baumtools.com/pdf/FERRARI_CAT_2008.pdf number FR 106
    but this tool not engaging the nut...I'm afraid there is no washer under this nut, so tool FR106
    cannot go deep enough to turn this groove nut.
    Anybody have a solution for this problem ? Grinding the side from tool FR 106 so it can go deeper is a solution but I'm afraid it will weaken its possibiltys.
    Guido
  2. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    Hello Guido
    Can you post a pic
    I do not understand what the exact problem is
    The mondial is not in my garage so I cannot have a look on the car
    Have send a pm to you some time ago
    You must have missed that
    Frank
  3. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    #3 theunissenguido, Jun 24, 2010
    Because the flange is conic, tool FR 106 isnt going all the way in, and because there is no washer under the ringnut, this tool isnt making contact with this ringnut.
    I'm looking for a solution without using a hamer to break that ringnut....
    Guido
  4. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    #4 st@ven, Jun 24, 2010
    Guido
    contact me, i've got the right tool (meaning in this case: other manufacturer and very recently proven to work with a job on my gtb)
  5. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    #5 SeattleM5, Jun 24, 2010
    Hi Guido, I tackled this job as part of my winter project on the 328 last year. Before starting the project I looked at the Baum ring nut tool and was worried that it wasn't tapered enough to fit in the flange and grab the nut as you describe. With the help of my father (who happens to be a talented gunsmith) we made our own socket with a slight taper at the end which worked great. You'll notice in the photo below that the taper is very subtle. You have to be careful because the nut calls for 158.5 ft/lbs of torque (at least on a 328) so if you taper the tool too much, the end may be too thin with resultant failure with that torque load. I suspect that the Baum tool has been treated/hardened so any modifications as far as grinding a taper may be difficult. You might try taking the tool to a machine shop and see if they'll throw it on a lathe and taper it for you but again this may be challenging if the steel has been hardened. Best of luck.
  6. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Nice work!
  7. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
    Guido, what made you want to change the bearings? Was she wobbling at speed or something?
  8. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Great looking tool you guys made there. Do that with a rotary table and a milling machine?
    What did you start with? A large socket or ?
  9. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Guido, Ettore is right - the Baum tool is probably hardened, so, lathing a slight taper on it will take good carbide tooling and a good quality lathe. If you don't happen to do such things yourself, and want to try a less elegant means you could try grinding a slight taper on it with your bench grinder. It'll be slow work, but you'll get there OK if you're careful. Like Ettore said, don't take off any more material than you absolutely need to!
  10. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    Thanks Cliff. We started with a hunk of cylindrical steel that my father had lying around the shop (a remnant of a blank used originally to make a long range rifle barrel). The outer diameter of the blank was close to spec but needed to be turned down a small amount using a lathe. The taper was also achieved using a lathe. A milling machine was used to achieve the inner configuration. Before handing it over to me, my Father "hot blued" the socket to give it the dark appearance you see in the photo. While completely unecessary given the tool's application, bluing is a process of "electrochemical conversion coating" that oxidizes surface steel thus providing corrosion protection. He was bluing a batch of rifle parts and thought the socket would look cool black. http://en.wikipedia.org/wiki/Bluing_(steel)
  11. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    Nice piece of work your father did, Ettore.
    It isnt for my car, but a friends car. The bearings did make a houling noise in corners and in the end even driving strait. I dismanteled the complet wheelset and in order to break things, he left it at a local Ferrari workshop. St@ven has a tool that would fit also...I'm looking forward to know more about it...and will let you know.
    thanks, Guido
  12. Paul308GTSi
    Paul308GTSi Formula 3
    Oct 26, 2008
    1,003
    Queensland Australia
    Paul D
    You dont necessarily have to use a lathe tool when turning something down. You can cheat and make a clamp for a 4" angle grinder to be bolted into the tool post .
    Turn the lathe on AND turn the grinder on and use the grinder to machine away what high speed steel ( and many tip tools ) will not handle.
    Like a lathe tool basic rules apply , keep the wheel at centre height etc etc ...
    A good practice is to either cover the lathes bedways during machining or clean them thoroughly after you finish the job .............. or both.
  13. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    "I have the right tool from Baum tools
    but this tool not engaging the nut...I'm afraid there is no washer under this nut, so tool FR106 cannot go deep enough to turn this groove nut."
    How can this be "the right tool" if it doesn't fit??? What the hell is wrong with the designers at Baum??? "There 'otta be a law".
  14. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    There is noting wrong with this tool, only there is no washer under the ringnut...so the ringnut is to deep to engage foor tool FR106.
    For some reason Ferrari whas out of washers at that time of building> Not only this washer is missing, some others to...saving money policy, I think. And I'm also shure this is the first time ever someone worked at this ringnut (yellow paint still original).
    Guido
    How can this be "the right tool" if it doesn't fit??? What the hell is wrong with the designers at Baum??? "There 'otta be a law".[/QUOTE]
  15. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    #15 FF8929, Jun 27, 2010
    [/QUOTE]
    Oh.......I withdraw my comment. Still, for the cost of Baums tools, they could have added the chamfe,r in anticipation of a missing washer. But, none the less, I was wrong. Mea culpa.
  16. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    The complet set came back from our local ferrarishop. Bearings are shanged only. Dust-retainers and ringnut are re-used. Axle whas driving out with a press, bearings by heating the housing. We put evering back and everything is fine.
    Bill ferrarishop about 330 euro incl taxes.
    Guido
  17. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Somebody used the proper tool to put that nut on and torque it down in place in the first place....and, without a washer underneath it. So, there's a tool out that fits, and that will adequately bear the torque spec, even without a washer under the nut. That tool may be in Maranello however.
    Personally, I'd just take the baum tool and put a very small taper on it with some good tooling and my lathe. Another way I could do it is with the rotary table and the head on my milling machine inclined a couple of degrees. In either case, if only a modest amount of material is taken off then it should be fine and fit.
    Any decent machine shop could do this in about 10 minutes too.
  18. theunissenguido
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    That Ferrari workshop wouldnt show us their tool...maybe they just used a hamer and chisel to take the ringnut off.
    After they put a washer under the ringnut....the washer is at least 4 mm thick.
    Guido
