Mondial Roof Lining Question | FerrariChat
Discussion in 'Mondial' started by fez1238, Jan 7, 2008.
  1. fez1238
    fez1238 Karting
    Sep 5, 2007
    170
    Help
    Does anyone know if the roof lining on my Mondial 8 '81 is compatable with the roof lining on an Mondial 83 QV??
    For example do the handles and fitting points match up. No sunroof on both.
    Eurospares seem to have different part numbers but I cant see any difference in the diagrams.
  2. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Yes they should be exactly the same.
    If you are in the Uk I have a superb condition non sunroof lining that I removed about 6 months ago. All I have done is sold the two lights and the loom that goes with it. You could visit anytime and it takes abut 15 minutes to fit.
  3. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Agreed, there is no difference, I fitted an 8 lining to my QV five years ago, bit tricky but no real drama to fit.
  4. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    I found it simple to remove.
    Just undo the sun visors, then remove the grab handles and it then drops down.
    It was easier for me as the seats were out
  5. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    removing was easy, putting it back, on my own, was the tricky bit! I also wanted to recover the got the last roll-end of factory material from Italy, cost three ams and two legs!
