Mondial rust repair - simple or serious? | FerrariChat
Discussion in 'Technical Q&A' started by Wade, Jul 8, 2008.
  1. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I've been looking at a t coupe that has some rust under the hood (front and rear) weatherstripping. After going through the parts manual on Ricambi's website it doesn't look like it'll be a major repair.
    Has anyone experienced this yet?
    Pics Here
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,334
    Edwardo
    #2 350HPMondial, Jul 8, 2008
  3. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    Haven't seen it that bad here in CA, but one caution is that there is actually significant missing metal (or will be, once you grind it down to clean). Might require something welded on there.
    My other concern is that this won't be the only rust on the car. You can almost bet on it.
    I hope this one's priced very cheap.
  4. Bullfighter
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    Beat me to it... looks like a good repair.
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #5 Wade, Jul 8, 2008
    Thanks for the input but like you've both mentioned there may be more rust inside (PPI only found what's shown).
    $1500 sounds a lot better than 4 or 5K.
    Parts-wise, at most, item 31 might need a replacement.
  6. f355spider
    f355spider F1 World Champ
    18,053
    I have not seem that much before, but looks easily fixable. The much bigger concern, what the hell storage conditions did the car receive to get that way? Most likely it was parked outside a lot. I would inspect the entire car for other hidden rust.
  7. jh355
    jh355 Formula Junior
    Feb 12, 2004
    424
    Halluci-Nation
    Craven Morehead
    Use sandpaper or steel wool and remove as much loose rust scale as possible, then squirt or rub Rust-mort or Navel Jelly on all the rust area to pickle it. If you do not remove and pickle ALL the rust, it will simply come up again through your paint at a later date. Use a good primer and seal the area then top coat it with semi-gloss trim black. It would be much easier to work on the hood removed from the car.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Craven's on the right track, however, POR15's system will take care of the rust & prevent it's recurrance.
    A quick search of Tech Q&A for POR15 will bring up several links & a couple of 'how2' posts.
