Mondial Solenoids for the rear hatches | FerrariChat
Discussion in 'Mondial' started by 4ARI, Feb 22, 2007.
  1. 4ARI
    4ARI Formula Junior
    Dec 15, 2005
    484
    Northern, VA.
    Ron S.
    Does anyone have a source for used solenoids (poppers) for the rear hatches. I need to replace both solenoids on my '89 Mondial T (one for the rear trunk and one for the engine compartment). Ferrari parts are $1000 each.
    I'd love to find some used ones out there.
    Any suggestions?
    Thanks,
    Ron
  2. CFCARRIAGE
    CFCARRIAGE Formula Junior
    Jun 9, 2006
    598
    Missouri
    Dave
    Ron, are you sure it is the solonoid? Have you cleaned all of the electrical contacts in the trunks? My contacts were all corroded but I cleaned them up. I only have one issue now the rear trunk switch.
    My 89 Mondial T has the same issue with my rear trunk, but for some reason I think it is the switch in the dash and not the solonoids. I looked at the part price too and for now Im sticking to the manual trunk release. I'm waiting for someone to part out a Mondial to get their part. maybe someone here knows of a similiar part made by another co.?
  3. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    When I first got our Mondial the gas cap solenoid wouldn't work. After I spent a large amount of time figuring out how to get it out to find out what was wrong with it, I discovered that it was just a dirty switch in the console. I cleaned the switch with electrical contact cleaner and haven't had an issue since. Just food for thought.
    Birdman
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Radio Shack electrical contact cleaner spray.
    It's the front switches - happens all the time.
  5. 4ARI
    4ARI Formula Junior
    Dec 15, 2005
    484
    Northern, VA.
    Ron S.
    All good suggestions but my mechanic just changed the switches in the dash as a way of trouble shooting. With brand new switches (only $26 each), the lids still do not pop. He now thinks the problem is the solenoids. I'm not going to spend $1000 for each so I'll wait it out although if my mechanical cables brake, then I'm in real trouble.
    ROn
  6. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,958
    The Cold North
    Tom
    I have replaced a few of these on the Mondial series. They do fail. Most times they melt due to bad switches..so replacing the switches was a very good thing to do. I always replace them in pairs. I found a place in my area (canada) that can rebuild the solinoid, and they are currently looking into a replacement that will be a direct fit. I will have to call them up to find out if they have had any luck. They really should cost no more then 100 bucks for the part.
  7. nationofzeros
    nationofzeros Rookie
    May 14, 2006
    23
    dreamy doncaster
    chris elliot
    Hi - the front bonnet solenoid on my 93 Mondial t wasn't working - I dismantled it and found the windings insulation had somehow melted around the core shaft. In the end I (rightly or wrongly) used a drill on the interior of the solenoid housing to cut back the melted plastic and create a smooth passage for the core. It now works - after a fashion. I wonder whether repeated / prolonged use of the switch causes the windings to overheat???
  8. tbakowsky
    Sep 18, 2002
    19,958
    The Cold North
    Tom
    This is why I always replace the switch and the solenoid together
  9. CFCARRIAGE
    Jun 9, 2006
    598
    Missouri
    Dave
    How do you get at the back of the switches to clean them ? I'm hesitant to go tearing into my dash. The ones in the rear trunk were easy to get to.
  10. davem
    davem F1 World Champ
    10,717
    Stepford, Connecticut
    dave m
    You basically pinch them on the sides and pull it out. Maybe use 2 small wide flat head screwdriver, put tape on sides of blade if so anally inclined.
    That said when i did it last, it did'nt seem the wiring in back had enough slack to pull it out enough to accomplish much.
    Good luck
  11. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    Just use jumper wires to put 12V directly to the solenoid and see if it works. That will be your definitive answer. If it doesn't, I would try taking it apart and seeing if you can fix it. It may be something simple on the inside of the solenoid. And in any case, at that point you have nothing to loose. If you fix it, great! If not, you were going to have to buy a new one anyway.
    To paraphrase that great mechanic Buddy Palumbo, "The mark of a true mechanic is actually FIXING something, not just replacing parts until the car works again."
  12. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    If anyone needs a boot/Bonnet solenoid or the switches, please Pm me, Pete
