Mondial spark plug wires | FerrariChat
Discussion in 'Mondial' started by Jim Kanely, Sep 15, 2014.
  1. Jim Kanely
    Jim Kanely Rookie
    Oct 15, 2012
    14
    Anyone have a tip on putting the boots on new Magnecor wires? Do you use a lubricant to fit the terminal end into the boot?
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #2 soucorp, Sep 15, 2014
    Soapy water works best as its slides into rubber boots/extenders, wipe with towel and let it dry out to a tight fit.
    Also works good for applying vinyl wrapping on cars etc.
    Best
  3. FamilyCar
    FamilyCar Formula Junior
    787
    Seattle, Wa
    Peter Goodall
    I believe I used a dry silicon spray lubricant, which I think was what they recommended or I read somewhere. I don't think it attacks the wiring material the same way a petroleum based product would. In any case, the wires have been in the car about 5 years and show no signs of problems.
  4. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    And one more suggestion was to freeze the wires and warm the boots IIRC. Makes wires a bit stiffer.
  5. Jim Kanely
    Jim Kanely Rookie
    Oct 15, 2012
    14
    Thanks, everyone. I'm going to try the silicone spray.
