Mondial Suspension & Sub-Frame | FerrariChat
Discussion in 'Mondial' started by StuR, Nov 11, 2009.
  1. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Apologies for repeating a tech-sec Qs, but I'm not having much look with responses... Anyone dropped their rear subframe on a Mon QV? I'm trying to find out whether all the chassis points should simply 'mate-up' on refit, or whether the suspension strut-tops should be under tension? My subframe had 27 years of loving care, so needed TLC and I have some pull on initial refit, which I want to ID as normal or not. Thanks for any advice...
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    no, it doesn't just fall back into place. Mostly the top shock studs catch and need a 'fettle'.
    HTH, Brian
  3. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Thanks Brian, I have 'about' 15mm (I am away from the car and can't remember exactly) to pull back into place to line up the subframe and frame holes, purely on the suspension tops - all other areas are fine. Seemed like a lot of pressure to put on the studs.
    StuR
  4. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Yes, that's more than what mine was. I think it will still be OK though.
