Mondial T 3.4 oil change | FerrariChat
Discussion in 'Mondial' started by Wingnut, Nov 6, 2022.
  1. Wingnut
    Wingnut Karting
    Feb 11, 2005
    155
    Corolla, NC
    Sorry, I was timed out of a caption.
    After putting 10 Qts in the Mondial T, I inverted the 10 "empty" plastic containers in a collection bowl overnight. This 1/2 pint was the result of what came out of the "empty" 10 conainers. More than I had expected.
  2. Wingnut
    Wingnut Karting
    Feb 11, 2005
    155
    Corolla, NC
    More revelations
    5 quarts drained out of the engine, 5+ quarts came out of the 22mm oil cooler hole
    10.5 quarts filled the engine with a new filter. 11.5 as per specs may overflow the "max" on the stick
  3. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    170
    EU
    J.Schulz
    Morning Wingnut,
    Thanks for sharing these observations.
    I guess the difference between specs and true fill might result of old oil still sitting in some minor canals (why else would new oil start changing color after only a few runs) and maybe more relevant for the mentioned difference in volume: The new filter is completely dry and shall undoubtly soak up quite some oil at first.
    Please share if after a few drives you have to top up some oil again.
    Best,
    Mondi Cab
  4. DocBasilone
    DocBasilone Karting
    Apr 15, 2020
    164
    NW PA
    I guess that why they say put in 11 LOL
