Mondial T check Engine Light | FerrariChat
Discussion in 'Technical Q&A' started by Aris64, May 15, 2024.
  1. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    After a very frustrated event when purchasing the car the engine was not firing because cylinders found fouled with oil! The cause was that the engine had about 20 L of oil instead of 11 L which eventually found its way through air induction to make a mesh! Anyhow, the engine started with fresh oil in the correct quantity and new spark plugs in a thick cloud of smoke burning remaining oil for some time. After that I noticed that CEL 1-4 was ON intermittent occasionally, supposing that λ sensor was contaminated by oil and getting 1114 fault code (λ sensor). When this happens idle has an up-down behavior which is very frustrating in the traffic. I did only a few kilometers and started (always in traffic) to have momentarily ON also SLOW DOWN 1-4 with fault code 4121 (catalyzer temperature ECU) while 1114 disappeared. I suppose that this is a false alarm since I am stack in traffic but not sure. My idea is that all mesh occurred from the contamination of the exhaust system. I am on the way to replace λ sensor but in the meantime the engine is not easily firing as before and exhaust fume smelling too strong and bad. These seem to be a clear evidence that situation goes worst... Any other idea or suggestion? Any similar experience?
    Thanks all in advance
  2. mcw
    mcw Formula Junior
    552
    A potential source for the problem is someone draining the gearbox oil and then over-filling the already full engine oil. In addition to problems you are experiencing, the gearbox may be missing its oil also.
  3. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    Fortunately the gear oil level is correct.
