Mondial T different engine versions | FerrariChat
Discussion in 'Technical Q&A' started by Aris64, Jul 30, 2024.
  1. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    I need a bit of help. My Mondial T (1991) is a Euro car and according to its manual would be fitted with F119D040 engine, however the engine on the car is F119G040 which according to US manual is fitted to the USA specs cars. The engine is the original, so really don't care why a G040 is fitted to a EU spec cars but here comes my question, D040 engine has slightly different settings in valves clearance and timing settings. Below photos are from the manual showing the different variants. I suppose that since I have a G040 I shall go with it's settings, am I right?
  2. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    Forgot to mention that the car had cats that now replaced with test pipes.
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,245
    Georgia
    Wade Williams
    I suspect the different is emissions related. With no cats involved you are likely to have no issues with either setting. Maybe look up camshaft part numbers and see if they are different. You may be able to find the number on your cams and see what you have.
    Aris64 likes this.
  4. Steve Magnusson
    26,985
    #4 Steve Magnusson, Aug 1, 2024
    Maybe not. I believe the F documentation shows that the early euro Mondial t (Motronic 2.5, little emission stuff) would be the "D", but that later euro Mondial t (Motronic 2.7, with cats and air injection same as the US) would be the "G". There are two different euro Mondial t OM (early 553/89 and late 737/92) -- what is the print number on the Mondial t OM that you are referencing?. On cars with cats and air injection, they typically increase the exhaust valve clearance a little and fiddle a small amount with the cam timing, as Wade indicated -- i.e., if your car has/had cats and air injection = G.
    Ferrari Tech likes this.
