Mondial t Engine Out Major Service | FerrariChat
Discussion in 'Mondial' started by paulchua, Oct 5, 2022.
  1. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
    Huge thanks to my good friend @yelcab for his infinitely gracious services. This is our second go for the engine out. (5 years go by quickly)
    Some findings.
    1) Driver cat is shot; one comes from another great source redbaycars.
    2) Replacing injector cables
    3) Crankshaft seal leaking - replaced
    4) Tripple shaft gasket leaking - replaced
    5) Shift linkage seal leaking - replaced
    6) Actuators seem to be in good shape
    7) Airconditioning compressor shot; got a new one from Eurospares on the way
    8) Replaced passenger side exhaust manifold
    9) Valve timing adjusted, new belt, the hill bearing tensioners
    10) Secondary air injection bolt shot (cross threaded) - going to fix that
    If you ever need a knowledgeable tech, reach out to @yelcab
  2. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
    Got some Japanese branded Air Compressor from Eurospares; Mitchell thinks he's going to swap out the pully wheel as the new one has 6 teeth vs. the 4 on the OG. I thought the newer one was probably much more modern than the OEM; both same price, so what the hell. Got new injector cables from Kingsborne on recommendation and a big plug to Stefan at RedBayparts for the cat on its way- Stefan is a man to be trusted. I've done business with him for many years now. He is always a gentleman.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    All that work to change the plugs, man do you like to do things the hard way !!!!
  4. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
    Oh much more then plugs my friend…
    i mean folks seem to like to go gas tank route, let’s just say my buddy has engine outs figured out.
  5. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Why did you replace the manifold?
    How did you know cat was bad?
    paulchua likes this.
  6. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
  7. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,978
    Southlake, TX
    Rob Lay
    big fun project! awesome.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    You be careful splashing out all that money, your neibours know you are a spendthrift so they will think you are ill if you break into a $50 note.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,471
    Menlo Park, CA
    Paul Chua
    Okay, almost done. Again big thanks to @yelcab a true asset to the Ferrari community.
    Just putting the cat back and plan to have er' back on the road next week.
    Best wishes to the Mondial Family.
    Cheers
    DocBasilone and ronfrohock like this.
