Mondial t left side not firing | FerrariChat
Discussion in 'Technical Q&A' started by Lino, Nov 30, 2011.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi,
    I have been having this trouble on and off. The left side of the engine does not have any ignition spark.
    I changed the ignition module and the coil pack already and switched the ECU to make it was not that.
    Any ideas.
    Lino
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Crank sensor or wiring issue?
  3. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,764
    US of A
    Michael
    Check the ground harness/wires that are located along the intake manifold. Secondly check the MAF. Then confirm the fuel regulator is working.
    Keep at it. Its a simple system.
  4. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi,
    and thanks. I have limited knowledge how would I go about checking the MAF and fuel regulator.
    If it would be the cranksensor has anyone repalced on a Mondial T?
    Lino
  5. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    Please check the fuses next to the exhaust ECU in the trunk.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #6 ernie, Nov 30, 2011
    After checking the grounds, I'm with porphy, my guess is bad Cat Temp Ecu. Try disconnecting the cat temp ecu for the bank that isn't firing. The Mondial T is pretty much the same as the '89 348 with a few things in different locations.
    As for changing the crank sensor, EASY. Same deal as on a 348. So you can run a search of the archives for the d.i.y. threads.
    One more thing. Do both of your c.e.l.'s come on? If so, you may wanna pull the codes to see if you are getting the cat ecu code, which for the 348 is 4121.
  7. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,764
    US of A
    Michael
    #7 Michael B, Dec 1, 2011
    These are all great ideas.
    To check the MAF you could check ohms, but to make it easier you simply run the car & unplug the connector @ the MAF and see if you have a change. Report back with findings.
    The fuel reg you just need to pull off the vacuum hose and tell us if it spills fuel out. If its dry (and it should be) you should be okay.
    I also agree with the ECU fuses (located back by the ECUs) and perhaps the Cat Temp ECU (however mine never had a similar failure).
    Lastly remember that each side works as its own entity. It would be pretty simple to just crack a fuel line open and see if you have fuel flow on each side. Jot down results on any of the above and post back.
  8. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hello,
    I have fuel and i will be checking fuses.
    I dont get any slow down lights.
    A for the grounds what is it I am looking for. I will be checking wires today.
    Then I will see for the crank sensor. BTW does anyone know of a cross ref. number for the cranck sensor. Do we have a match?
    Thanks for your help guys.
    Lino
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #9 ernie, Dec 1, 2011
    Yup.
    Kia cranks sensor. http://ferrarichat.com/forum/showthread.php?t=228857 Running a pair in my 348 as are a few other guys.
  10. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hey Thanks, going to order two as i speak. i am just wondering if i will be able to do this with TWO floor jacks????? What do u think?
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    That's what I used, and a couple of jack stands once I had it in the air. 15-30 minute job once you are under the car.
  12. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    The Kia ones are working great. The replacement is exactly as Ernie says. Easy peasy, even I got it done with all thumbs and frustrated mechanic mentality! Good luck.
  13. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok got the Kia sensor, I am going to buy second jack tomorrow.
    I will keep you posted.
    Lino
  14. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi,
    I jacked up the car and changed the higher mounted crack sensor for the left side, is this correct?
    Anyway I started the car and it was the same problem, the right side is not firing?
    Need help.
    Thanks,
    Lino
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The crank sensor on the side of the pulley is for the 1/4 bank (right side of the engine looking in from the back of the engine bay), and the crank sensor on the bottom of the pulley is for the 5/8 bank (left side looking in front the back).
    Try swapping it with the bottom cs, and see what that does.
    If that doesn't work then I would try completely disconnecting the cat ecu from the harness.
  16. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok so I guess I changed the wrong one. i changed the one on the seide of cranck pulley. I have the left bank (looking from the back in) not working so i had to change the bottom one correct. so back up we go.
    I noticed that the 7.5 amp fuse next to the left computer was blown. I replaced it 3 times and everytime i started it blew?? i included a picture, I am pointing at it with the tester. Could this be the smoking gun?
  17. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    #17 Lino, Dec 2, 2011
  18. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,764
    US of A
    Michael
    #18 Michael B, Dec 2, 2011
    Sure could.
  19. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    anyone know what that is for?
  20. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Ding ding ding ding ding. We have the winner folks.
    So is that the fuse for the cat ecu?
  21. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    beats me. I am reading the manual and I cant find it?
  22. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi Guys,
    Anyone have an idea what that fuse is for? I am looking in the manuals ans I cant find it.
    Lino
  23. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,764
    US of A
    Michael
    #23 Michael B, Dec 3, 2011
  24. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Says 27 is for the injection system.
  25. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    i will look around early tomorrow morning to see where that wire leads. Thanks guys.
    Keep you posted.
