Mondial t left side not firing | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Lino, Nov 30, 2011.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok so I looked around can't find anything shorting. I think I am going to have to dig deeper, does anyone have a wiring diagram for a 348 or a Mondial t.
    Lino
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Maybe it's a blown relay?
    I'm totally guessing at this point.
  3. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    I have to see what what that relay is for?
  4. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hey thanks.
    The relay is : Injection system electromagnetic switch. The question I have is why would that cause left side not to fire if it's an injection relay.
    How can I check if a relay is working, I would like to test.
    Thanks for all the help
  5. Steve Magnusson
    26,932
    #31 Steve Magnusson, Dec 4, 2011
    Motronic uses a combined injection+ignition ECU so they are just sort of abbreviating the name/function of that relay (i.e., it serves the ECU that controls both the injection and ignition functions).
    The schematics in that Mondial T WSM are particularly user hateful, but they (pages 190 and 191 of 652) indicate that the fuse (with the brown? wires) that you show as being blown in the photo is for the fuel pump -- not the Motronic ECU. Can you please confirm the wire color on the 7.5A fuse that keeps blowing (that current rating seems kind of low for a fuel pump), and the wire colors and current ratings for the other 2 fuses in that same area?
  6. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi Steve,
    Thank you for responding, I really appreciate all the help.
    I really can"t understand the electrical diagram, I a have a workshop manual I downloaded and the daigrams are not very clear or user friendly as you wrote.
    The fuse is 7.5 amp and its the same set up on the other side next to the right ECU. There is a bigger brown wire which leads into it and another smaller gauge brown wire with a white stripe which leads to it on the side of the fuse holder.
    I changed the coil, the electronic module and the crank sensor for that bank before stumbling on this fuse. I have changed it 4 times and it keeps on blowing when I start the car.
    thanks,
    Lino
  7. Steve Magnusson
    26,932
    The 7.5A fuse value is probably OK. Usually, EFI fuel pumps run in the ~5A range (and the fuse might be selected to be 2X that value), but I have no exact current data for your fuel pumps so the current might be a little lower.
    However, the fact that it blows is a terminal condition for operation, and, based on the horror stories/photos posted here about 348 fuel pump internals falling apart and clogging, could be your problem.
    Can you clarify how many fuses & relays you have associated with each ecu? That schematic shows 2 relays (one for the Motronic ECU and one for the fuel pump) and three fuses (fuel pump, Motronic ECU, and O2 sensor heater), but, if you had a 2.5 Motronic without O2 sensors, you'd only have two fuses with each ECU. Also, the schematic shows that that fuel pump fuse should have two large MB (brown/white) wires, but little differences like one wire actually being M (brown) and one wire being MB (brown/white) are not uncommon to find. However, IME, F has a history of using brown (or beige) as the base wire color for the fuel pump operation so I'm fairly sure that that's the fuel pump fuse, but, if you can give the wire colors on the other fuses, that can be another way to be a little more certain about things. The WSM schematic for that side shows:
    Fuel Pump Fuse = MB (brown/white) wires
    Motronic ECU fuse = RN (red/black) wires
    O2 Sensor Heater Fuse (if present) = S (pink) wires
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    HURRAY!!! Someone who knows what they are talking about, because I sure didn't know where to lead this guy anymore.
    Rock on Steve!
    You have a VERY good point about the fuel pumps, and that never even crossed my mind. I don't know for sure if the Mondial T has the same fuel pump set up as the 348 but, ....... I think these threads could help him out with some.
    Page #2 of this thread http://ferrarichat.com/forum/showthread.php?t=193188 has the fuel pump removal from the tank.
    And here is the thread for the fuel pump once it's out. http://ferrarichat.com/forum/showthread.php?t=224988
  9. Steve Magnusson
    26,932
    I just checked the 348 WSM and that shows a much more reasonable EFI fuel pump fuse rating of 15A -- Ernie, can you confirm that this is true?
    If your Mondial T has been working OK with a 7.5A fuel pump fuse, but it now blows, that's a clear sign that things might be getting worse for that fuel pump -- but it would sure be good if someone else with a Mondial T (or someone who knows where they are shown in the documentation) could confirm/deny those fuse current values (I couldn't find anything for those fuses in the Mondial T WSM nor the Mondial T OM).
  10. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi Steve,
    I will be back home in a few hours and I will confirm the wires on the other relay.
    I just find it wierd the pump would go, I only have 14000 miles. I just had a major one a few weeks ago and it was running fine till I went and fill her up.
    I wonder if maybe a wire was clipped but it would have shorted out sooner if it was that???
    Anyway I will confirm wires by this afternoon.
    Hi Ernie,
    Thanks for the links to the thread, I hope I don't have to go that way. I have full tank go gas.
    Thanks guys, :(
    Lino
  11. Steve Magnusson
    26,932
    Wire colors on the other fuses (not relays).
    I think the issue is more 20~25 years soaking in gasoline/gasohol -- not the mileage, but I'm still suspicious of that 7.5A fuse as the 348 seems to use a more reasonable 15A fuel pump fuse (see prior post). Do you know anyone else with a Mondial T to compare?
  12. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi steve,
    Ok so I checked the wire on the fuses and not the relay. The other fuse holder next to relay has Red wires and the othe fuse next to the other relay is pink.
    I will ask around to se what fuse is in there, what do you think if I trr a 10 amp/
    Lino
  13. Steve Magnusson
    26,932
    #39 Steve Magnusson, Dec 5, 2011
    That sounds good, and quasi-confirms the functions of those other fuses to match what's shown on the schematic. But what are the current ratings for those fuses? Are they all 7.5A? (7.5A does seem a reasonable value for both the ECU fuse and the O2 sensor heater fuse.)
    I see no downside to trying a 10A, or even a 15A, fuse for that fuel pump fuse as a brief test. This is where you'd really like to measure the actual currents that the fuel pumps are drawing during operation (and they do make inexpensive high-current ammeters that plug into that style fuse socket). For example, if your "good" fuel pump was drawing ~5A and the "bad" one was drawing 6~7A, I'd have no problem saying that you could just drop in the 15A fuse, and use as normal. However, if your "good" fuel pump was drawing ~5A and the "bad" one was drawing 12~13A, I'd say that, even if it worked OK with a 15A fuse in place, it is really not good anyway, and needs to be addressed. Of course, if the 15A fuse blows immediately, you know that you've got some sort of serious problem.
    All JMO (and would like to have a comparison with another Mondial T and get confirmation that a 348 uses 15A for the fuel pumps) -- please proceed at your own risk
  14. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    I took a chance and tried the 10 amp and it blew.
    Friend says they are 7.5 amp.
    I tried to follow the wire but the only thing close to it was a brown wire going to the electronic module next to the coil pack??? I changed the module and put back the old one?
  15. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yup 15A.
  16. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
    #42 porphy, Dec 5, 2011
    Mine was 7.5 amps. Blown but I replaced and have no problem as yet. Brown wire. In my case the brown wire under the passenger foot well was melted and I expect contributed to my problem. I rerouted the brown wire in the foot well around the plug and have had no problems since.
    Work Shop manual, Page C3
  17. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok but other Mondial T has 7.5 amp fuses. I tried to see whaer it leads but no luck. I read another thread where it lead to a burnt connnector wire in passenger foot well. I checked there and it all seems ok.
  18. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    #44 Lino, Dec 5, 2011
    I see the relay in question and it says Matronic system relay but it only shows one fuse on it when there are 2.
  19. Steve Magnusson
    26,932
    Thanks for the confirmation Ernie. I still can't fathom how two electric fuel pumps, operating at the same voltage and delivering the same volume at the same pressure, could have such different currents (but perhaps its related to some inrush behavior difference).
    Lino -- Don't really have anything else to add, but we'd always be interested in knowing what was the problem and what was the fix when you get it sorted.
  20. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    As soon as I get it sorted I will chime in. After some reading the relay say its for the Magtronic system.
  21. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #47 ernie, Dec 5, 2011
    Motronic, it's Motronic.
    Anyway.
    Try swapping it with the relay for the other bank and see if the "dead" bank jumps sides. That is if you have 2 ecu's.
  22. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Motronic, got it.
    I may try that in the morning. I just had to walk away tonight, I just hate when this kind stuff happens.
    Thanks for the tip, I will let you know how it goes.
  23. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    #49 Lino, Dec 6, 2011
    Ok so we are running on all 8 again. I found the wire to the fuel pump touching the bottom cover. I must of hit a bump and because rubber shielding the post was cracked it shorted. Thats all it was, a 7.5 amp fuse shorting and because ther was no rotation sensed the ECU did not send a spark.
    My mechanic did help me out with the colour codes, my diagram is black and white.
    I included a picture. The universe is good again. :)
  24. porphy
    porphy Formula 3
    1,210
    Randall Gatz
