Hi All, Can someone let me know which side of the car the drain plugs are on (Left or right and front or back) of the engine? Want to be sure I can locate the correct ones. I have found this referenced but it's not clear and it was from a 3.2 Mondial ferrarichat link not the 'T". Any other tribal knowledge that can be shared will be greatly appreciated. I have the 12mm allen wrench for the 10275011. Notes from the other post say the other is a 22 or 24mm. Thanks for looking.
The T is probably completely different to the 3.2 and you may find more accurate data in the 348 section as that is basically the same engine & gearbox - having said that my Mondial T workshop manual shows similar locations and in fact the same drawing even - hmmmm - just checked the 348 looks the same as well
Yes, that image is from the Mondial t. I just grabbed this from the 1993 Mondial t Owner's Manual. Image Unavailable, Please Login
Oil change plug are in 2 places. 1. Under engine, close to center, oil plug facing the front of the car. 2. Under right hand side, ahead of the rear tire, is the oil tank. Plug faces the ground.
