Mondial T Passenger Footwell Plugs and connections | FerrariChat
Discussion in 'Mondial' started by porphy, Jul 20, 2024.
  1. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    I am re installing the dash after replacing the blower motor. My dashboard instruments do not light up after replacement and connection. I have questions about the connectors in the space behinds the passenger footwell. Have I made a mistake in the connections? Does anyone have a photo of those plugs? I know some but not all are fool proof sur to the con figuration of the plug and receptacle. A photo might help. I have checked the plugs around the ignition switch cable and they are functional.Thanks in advance. Randall
  2. Aris64
    Aris64 Karting
    Feb 26, 2024
    78
    Greece
    Aris Arvanitakis
    I don't think that footwell electrics are related to your dash lights problem. In the attached photos you may see the related connectors and the parts located there. Actually you can see the suspension ECU and the A/C ECU. There is a 3rd controller (is not visible in the photo) which is located normally between the two and is used for the exit cabin light delay circuit.
  3. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    Thanks much Aris64. You have confirmed that I have them all correctly connected. Which is very helpful. I will look elsewhere for the dashboard instruments function. Thanks again.
  4. Aris64
    Aris64 Karting
    Feb 26, 2024
    78
    Greece
    Aris Arvanitakis
    I have spent hours of study on the wiring diagrams of Mondial T and I can say that I feel quite familiar. All the information is included in the WSM which is available through several resources for free (the one of 676 MB). The analysis is important especially for the wiring details as you need to magnify the image to see the color coding of wires. If you need help in some particular area maybe I can help.
  5. porphy
    porphy Formula 3
    1,209
    Randall Gatz
    I now seem to have power to the instruments but I am not convinced. When I turn the key on I do not get a gas gauge reading which I think it should give me.I have dash lights and other lights working. I will continue to investigate and observe. Checked all fuses and plugs. Thank you for your offer. I am not at the point where I can use you effectively. Randall
