Mondial T - rough idle, tach way to high | FerrariChat
Discussion in 'Technical Q&A' started by nicce12, Jul 3, 2013.
  1. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hi,
    I have a 1990 Mondial T (i.e. motronic 2.5) that idles rough, seem to overheat right cat and the tach is most of the time showing 4500 when idle (engine revs are around 1000 I would judge) cold as well as fully warmed (fans kicked in). To start I need to press the gas pedal a little bit.
    After checking sparks I can see that I have sparks on all cylinders on the right bank and the left bank.
    I did a second test run after checking the spark and occasionally when you drive with a bit of engine rev the tach will show real rev (over 3000) and it will run fine with a more "turbine sound" compared to the stuttering when she misses. When driving with even gas she will stutter and "pull" most of the time though.
    I am thinking crank sensor issue - am I way off?
    I will lift her up and check the connections for the crank sensors, anything else I should look at?
    Cheers, Niclas
  2. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    I would definitely think Crank Sensor. I replaced both of ours years ago with the cheap Kia sensors listed in the 348 parts exchange thread. No trouble since.
    Crank sensor - KIA: 0K2A6 18891 (~$30/each from dealer)
    At the cost they are certainly good for diagnostics if not a permanent solution.
    Bad O2 sensors can really monkey with the computer also, but certainly wouldn't affect the tach like a crank sensor. I think (not positive) the oxygen sensors can be unplugged temporarily (underneath the air filter box) for diagnostics, causing a default rich mixture but not to the point of overheating a cat..
    We also have two relatively cheap Walker o2 sensors installed that work just fine.
    Dave
    btw, Ferrari says not to touch the gas when starting as it may confuse the computer. Definitely not normal to have to do that.
  3. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    I was thinking if you haven't done so already you might also want to check the ECU grounds which are on the top of Cam covers. Since the car has been sitting I would remove and clean them for sure.
    Also, check your alternator output voltage. After our car sat in storage for 5 years Ferrari put in a new one prior to the sale. I know the ECUs are voltage sensitive.
    Dave
  4. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Try and check all of the Vac hoses you might have a leak,the leak can act as a miss.
  5. cfoster32
    cfoster32 Karting
    Nov 15, 2010
    131
    Cedar Rapids, IA
    Cody Foster
    It sounds more like an O2 problem. I've never worked on a Ferrari, but anytime that I've seen a crank sensor problem the tach will be very low, the car will stall occasionally and be very difficult to start up afterwards. Also check your right cat. Sometime a damaged or plugged cat will cause a rough running condition.
  6. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Thanks for all the help!
    I ordered the Kia crank sensors and will pick them up and install them tomorrow (a tip if you are in Sweden, Thurebergsbil in Upplands-Väsby carries spare parts to older Kia models, I had to call quite a lot of Kia dealerships to get hold of the sensors).
    I will definitely take a second look at the vacuum hoses, in fact I fiddled with them to check if they were lose and that could have accounted for the better running at the second test run.
    Alternator is on the rebuild list in the major service I plan to do next week... :)
    ...and I am ebaying after Stabilant 22a for all connectors and ground points, I will make sure to give ECU ground an connectors a good clean and some Stabilant when it arrives.
    The right O2 sensor has been spliced on to the Ferrari connector, probably a good idea to redo that work and measure the sensor at the same time - I was though under the impression from My Ferrari 348 that the O2 sensor only come at play when the engine is warm?
    Of cause I can have several issues at play at the same time... :eek:
    Cheers, Niclas
  7. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Sounds like you are well on your way to a smooth running Ferrari. My understanding (questionable) is the O2 sensors are heated so they don't need to be warmed up by the exhaust. I think the computer ignores them for only a minute or two while they heat up on their own. Also at full power they are ignored.
    However, We had a situation where the car would not hold idle from the get-go, had a nasty misfire (even at full power), intermittent check engine lights, and yet the problem was completely solved with new Walker oxygen sensors.
    Can't explain why.
    Dave
  8. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Thanks for the optimism Dave!
    I exchanged the crank sensors, but there was no change in the engine behaviour unfortunately.
    Tomorrow I will have a go at accessing the status of the alternator, there was quite a lot of crud around the front of the engine due to a small oil leak (seem to originate from one of the couplings for the oil lines) and the alternator was quite dirty.
    I started to determine which cylinder is out by pulling a spark plug cap, starting the engine, and noting the difference. I would say that removing cap from cylinder 1 made little or no difference while removing the cap from 2 worsened the behaviour. I will continue that tomorrow.
    I also removed spark plugs to take a look at them to try to determine which cylinder might be out (they are brand new so they should be only affected by the current running) - by some brain dead behaviour I started on 4 and worked forward instead of following the order I used when disconnecting the caps. 1 was clean with a little petrol film while 2 had a little bit of soot build up already and a petrol film, I will check the rest tomorrow.
    One funny thing though - I noted that the spark wires are dressed with heavy duty fuel lines and has a small tape on them with a number - I thought the previous owner might have numbered them to make sure they are on the right place but taking a closer look I realised that it is decimal number on them with values typically between 6,17 and 6,22 (5 on cylinder 4). Sounds like some measurement to me...
    Cheers, Niclas
  9. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    I measured the voltage over the battery to 12,9 volt with the engine off and with the alternator on idle to 13.5 going up towards 14 and over when revving the engine. When revving the engine I saw the voltage drop initially for half a sec and then pick up.
    I recorded a shaky mobile phone video and the engine was definitely running nicer today - and for the first time I got a Slow Down light! Slow down 1-4 lit up just after I shut down the video.
    Link:
    Mondial T, rough idle - YouTube
    Cheers, Niclas
  10. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Have you tried an ECU reset? It's free and sometimes is all you need.
  11. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    #11 davebdave, Jul 6, 2013
    That tach is wacky for sure. The engine doesn't sound right. The flat plane crankshaft design means that with a bank shutdown the car will idle like a 4 cylinder engine and I think that is what I am hearing. With the crank sensors ruled out, you can disconnect the cat thermocouple ecu's in the trunk to rule them out (small black boxes with silicone facing.) All they do is sense an overheat and run the slow down lights. However when they go bad they can wreak havoc on the ecu. Once they are ruled out you can think o2 sensor. But, I am still suspicious of a faulty ground. The engine is grounded to the subframe near the right cat. There are the cam cover grounds. And there is a ground somewhere under the dash. There is a thread somewhere where a Mondial t owner has a similar problem and after much troubleshooting, he solved it with the dash ground. I don't remember where it is though.
    I do agree that a global reset is in order. The battery shutoff switch is on the ground wire of the battery box. Turn it off for a few minutes. Then start without touching the gas and let idle for at least ten minutes without touching anything if possible.
    Beautiful car and setting by the way
    Dave
    Edit: it is odd to me that you don't have a yellow check engine light. Do they both test when you turn the key?
    Also could the spark wire numbers be compression readings in Bars or some other metric pressure measurement?
  12. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hi again - just a short update,
    I disconnected the battery (I have done that 2-3 times before over night to make the ECU re-learn with little improvment.)
    I then cleaned the terminals of the alternator with my Dremmel, the ground connections on the fire wall and also the ground strap between the engine and the subframe.
    The strap seem to be in good condition, I noted that the connections was drenched in copper paste and a the surfaces was a bit dull.
    I am not sure about the usage of copper paste on the ground strap, the stuff I have does not list is as being conductive - only corrosion inhibiting and facilitating easy removal of bolts and nuts.
    I removed the MAF's, cleaned them with electronic cleaner (non-residue stuff) and calibrated them to the factory default 383 - they read 470 and 475 (lean compared to factory default if I am not mistaken). If I get the car running ok I will tune it based on the O2 reading as described on this forum later.
    While I was waiting for the MAF's to dry I changed the air filter and cleaned the connections for the O2 sensors.
    Yet to do is to clean the ECU grounds on the cam covers - I can not for my life find them though ... ...and then I will clean the grounds under the dash as well and start her again.
    I will take a look at the Thermocouple ecu's as well - and try disconnecting them if she still runs bad.
    When I switch on the key I used to only get lamp test for brakes and the 3 red lights in the tach - lately I get lamp test also for the slowdown lights - but I have not seen the check engine indicators at any time. I read in a thread on another forum that lack of light test would indicate a faulty ECU...?
    Cheers, Niclas
  13. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    #13 davebdave, Jul 9, 2013
    Sounds like you are making good progress. Here is a photo taken from Nino's thread (http://www.ferrarichat.com/forum/mondial/364938-my-mondial-t-repair-project-part-2-a.html ) showing the cam cover grounds. They are the same on both covers.
    Also is a short video of the start light sequence on our car that I made for someone else a while back. The check engine lights are the last two on the annunciator strip to go out. Note the RPM is high due to the cold outside temperature but quickly settles around 1000 at idle.
    Check the bulbs as removing them is a proven fix for CELs. :)
    Dave
    [ame=http://www.youtube.com/watch?v=loj_fz-sK5c]Cold Start - YouTube[/ame]
  14. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    #14 nicce12, Jul 9, 2013
    Well, thanks to you Dave my cam cover grounds have now magically appeared - I can not understand how I missed them!
    Anyway, just got an hour to work on the car today (I was ordered to the beach, quite a waste of time I would say.)
    There was a bit of green fluff on the connections and I noted that the ground points were painted red and not clean metal. I understand that the idea is that the pointy washer should penetrate the paint and give connection but I decided to polish away the paint (I rather do a yearly routine of polishing the grounds then hope that the washer provides adequate connection). I also polished the connectors and gave the whole assembly a nip of connection spray.
    One cam cover ground to go and then I will hunt ground points under the dash and see if I can reach the bulbs for check engine lights. The weather guys has promised rain and cold weather tomorrow so I should be able to avoid the beach and get some work done...
    Cheers, Niclas
  15. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    The good news is once you get these cars sorted, they can be very reliable.
    But I wouldn't trust the belt and bearings for very long. I think you'll be busy for a while.
    Dave
  16. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi
    I had my troubles with bad idle and one bank shut down.
    I changed the crank sensor on bad side with no change. I do run with the thermocouple ECU's unplugged. According to my mechanic they are only there to protect from cat overheat. I have test pipes ( no cats ) so they are permantly unplugged.
    What cured it for me was new spark plugs, but what really did t was I cleaned the maf sensor plugs, as soon as I moved the plugs the engine would kick back to life on all 8. If you tap on the MAF sensors and idle fluctuates, it could be MAF is bad. Try to do your diagnosticsc as Dave mentiod with thermocoupler ECU's unplugged. These may be acting up.
    If you know which side is shutdown you can do coil swap and ignition module swap from working side. I bought some on ebay as spares. You will find some pretty cheap.
    I find that all important connectors, if moved sometimes play on the idle. And this is why eventually I may have to look at Dave Helms gold connector kit.
    I hope this helps,
    Lino
  17. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hi,
    Time for a update, I removed the alternator and had it renovated - it had a broken "diod bridge" according to the renovator. Unfortunately they put it together wrong so the attachments points did not line up and I had to take it back for adjustment (they did a mark on the front and the body on one of the ridges but a previous renovator had done the same markings on another ridge so they aligned them wrong).
    While I was waiting I had some time over and removed the exhaust to check the cats and they look fine. I also checked the light bulbs on the annunciator strip by removing the plastic window and they are all there at least, but I could not remove them with the tools I have (the light assembly seem to move inwards when I touched the bulbs) - or do I need to remove the dash to change them?
    With the alternator finally assembled I started her up again today.
    The tach works now as it should and I think she runs better but a bit nervous on idle around 1000 rpm.
    I let her idle 10 minutes and checked the cat temp regularly, the left cat reaches around 180 C / 334 F while the right goes up to 270 C / 530 F but it stayed there, previous it started to glow.
    After 10 minutes of idle I did a test run, right away the engine stayed on 2000 rpm - occasionally it would drop down to normal idle if I revved it lightly. Giving a bit of gas revealed only that I will need a new clutch... I stopped occasionally and checked cat temp but it stayed steady on the temp above, on the second stop I got the slow down light 1-4 when idling so I shut down the engine waited 10 minutes before I started, I needed again to give gas to get her to start and the 2000 rpm behaviour was still there.
    I suspect that bank 1-4 might be running in open loop due to the high rpm and warmer cat...?
    Here is a link to a video after 10 minutes idle:
    Mondial T after 10 minutes idle, renovated alternator. - YouTube
    Cheers, Niclas
  18. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hi again,
    After switching sides on Cat ECU's and then the ECU's with the issue with rough running and hot cat still on the right I moved on to measure the resistance of the ignition cables (all having around 6,12 to 6,35 Kilo Ohm), I decided to measure the fuel pressure from the fuel regulators before I go on with switching ignition modules etc...
    ...and now I am confused!
    I had the wife to control the ignition key since I bought an el crappo pressure gauge that basically just has a cone that you insert in the fuel line you want to test.
    I measured at the fuel line that goes into the fuel rail from the regulator and got no pressure on ignition key position one (as expect as I understand) but also on position 2 I got no pressure (waited 10-15 seconds) and even a 1-2 seconds of cranking yielded no pressure - and no fuel either (line was dry when I removed the gauge)...
    I tested both sides separately since I only have one pressure gauge and need to hold it in the fuel line and I got the same behaviour on both sides.
    I put back the fuel lines after applying liquid thread sealing designed for fuel/oil/gas and had the wife to crank it and after 3-4 seconds the engine started to ignite.
    Funny enough it run like a sewing machine for 10-15 seconds before it started to stutter and idle rough as usual...
    Should I attempt to measure the feed to the fuel regulator just to check the fuel pumps or did I do something wrong perhaps?
    Cheers, Niclas
  19. nicce12
    nicce12 Karting
    May 22, 2013
    76
    Stockholm, Sweden
    Niclas Olovsson
    Hi,
    After reading some treads on issues with idle air valve I decided to clean mine with MAF cleaner and switch sides - they seemed clean already before I cleaned them and switching did no change.
    Then I measured the output from the O2 sensors with my multimeter in line with the connection - positive terminal on the output connection and negative on the contact since I wanted to see their behaviour when connected. The left sensor achieved 465 mV and held steady there but the right was all over the place, jumping several times per second from 50 mV to 1,2 V to 350 mV to 0 etc and then it would sway around 260 to 370 mV for 5-10 seconds and start jumping again. From what I have figured that is not an expected behaviour...?
    I will replace that one and see if I get another behaviour from a new sensor...
    Cheers, Niclas
