Mondial T speedo problem | FerrariChat
Discussion in 'Mondial' started by gidleigh, Jan 22, 2011.
  1. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    My speedometer starts at 10 mph. I imagine it should start a 0 mph. So is there an easy fix?
  2. Steve Magnusson
    26,736
    #2 Steve Magnusson, Jan 22, 2011
  3. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Thanks for the Info. One of the reasons I was concerned was because when I drive by a radar speed sign the speedo indicates 5-6 mph faster then what the radar says. I thought maybe the needle starting at about 10 mph was the reason.
  4. Steve Magnusson
    26,736
    #4 Steve Magnusson, Jan 22, 2011
    Yes, that's sort of typical of all F speedometer -- a bit optimistic ;)
    Although most cars do read a little high -- because manufacturers don't ever want to sell a car (with new tires) where the speedometer reads too low for legal reasons. Consequently, the typical "nominal" speedometer reads a little high, and only the worst-case speedometer, with the greatest error to the low side in the manufacturing process, reads correctly (with new tires).
    Also, tires are their biggest diameter when new, so as they wear, the speedometer reads a little higher (of course, if you are running a different rear tire size than the stock size, that directly affects the speedometer reading).
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Don't know if your concern extends to actually doing something about the speed error...roughly $100 and some electrical under-the-dash diy. I am finishing up, have taken photos, and will be posting the procedure as soon as weather permits me to drive the car to dial in the speed correction.
  6. SonomaRik
    SonomaRik F1 Veteran
    Like said:
    - Bad News: A lot of Ferrari speedos show 10 MPH standing still.
    - Good News: A lot of Ferraris are fast even when standing still
    When your RADAR chirps, foot off the gas and let the engine bring you to speedlimit and you'll most likely be under. Then you can explain to the officer, anyway. as he'll almost always want to claim new revenue with you, how Ferraris are designed: I'm sure he'll listen :rolleyes: mine never do.
    glory of exotics....get you into more trouble but fun getting there.
  7. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Our t's spedo stops at 10 also. BTW, for a fairly accurate speed, double the tach in fifth gear.
    dave
  8. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #8 hank sound, Mar 11, 2011
    Rachel claims she's doing at least 10 MPH - when in fact, she's just warming up in her garage.
    So, I gotta' think that 10, standing still - is the norm :):)
    Cheers, Hank
  9. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    No worries, mine does the same thing.
  10. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    #10 lightning, Mar 12, 2011
    Mine is the same also, looks like it's normal, in fact the trip reset button would prevent the needle from returning to zero anyway.
  11. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Yes, I think it is normal. At lower speeds my speedo is about 3-4 mph slow. I went out yesterday with my gps and after 40 mph the speedometer is within the margin of error.
  12. davidgovett
    davidgovett Karting
    Apr 9, 2010
    134
    Ditto that. As I have to replace my speed sensor (called the Pulse Generator) I rely on my RPMs to gauge the speed and when the speedometer occasionally works, 4000 RPMs consistently equals 80mph in 5th gear. In fact, driving without the speedometer is not much of a problem. The only rush for me to replace the pulse generator is that it also advances the odometer. I need it working so I can keep up with my miles for maintenance. If the Tach goes down, I'm screwed! Can't live without that.
    This also shows how ridiculously simple it would be to freeze the mileage to keep it low for putting it on sale. (Just pull the plug at the speed sensor/pulse generator)
    Dave G.
  13. KKSBA
    KKSBA F1 World Champ
    15,297
    SBarbara-La Jolla CA
    KKSBA
    That's been a problem with Ferrari's FOR-E*V*E*R*...
    You see a car with 8,000 ODO miles and it looks like 50,000 well run for the hills...
  14. gwroclaw
    gwroclaw Rookie
    May 28, 2010
    17
    If you look closely at the speedometer face there is a small pin on the face to keep the needle from dropping below about 10mph.
    It is also ridiculously easy to take the speedo a part and roll back the odometer to whatever you'd like. I just took the speedo of my Mondial T apart to fix the trip odometer reset. It didn't work and turned out to be a cracked gear housing where the push button moves a "gear rack" that turns a set of gears to roll the trip odo backwards.
    Don't worry I'm not rolling the main odometer back. I recently got the car and it is full of small niggling issues like this one. I finally am getting around to fixing this one. My next one is fixing the turn signal lever reset.
    Since most ferraris change hands often requiring an odometer reading at re-titling time a car fax will indicate any odometer tampering.
