Mondial T stopped running- suggest elec checks? | FerrariChat
Discussion in 'Mondial' started by Fletchf1, Dec 27, 2021.
  1. Fletchf1
    Fletchf1 Rookie
    Jun 29, 2018
    8
    Banbury
    Christian Fletcher
    1990 t coupe. Was running fine. Suddenly went half power, ran for a mile or so, idled very lumpy for a minute, now no start.
    I have a workshop manual and wiring diagram. Can anyone suggest basic electrical checks I can run using a multi meter? To check the key sensors, relays, power to ECU, ignition coils and fuel pumps.
    I wish to avoid blindly swapping over expensive components for new. All I have tried so far has been new crank position sensors because aftermarket Kia parts were v cheap, no difference so put the originals back on.
  2. aec
    aec Karting
    Jul 28, 2011
    138
    Weston, MA
    Did any of the "Slow Down" warming lights come on before it went to half power? Temperature sensors on catalytic converters (if you have them) can shut down engine banks when cats overheat.
  3. 83Mondialqv
    83Mondialqv Formula Junior
    May 18, 2021
    338
    New York
    Vito L
    You should check the fuse box. Have you upgraded it yet? My mondi did that and it was the fuse box.
  4. Fletchf1
    Fletchf1 Rookie
    Jun 29, 2018
    8
    Banbury
    Christian Fletcher
    No dash warning lights, and no cat temp sensors are fitted. I have the original fuse box so will check all fuse and relay connections
  5. Steve Magnusson
    26,841
    When you say "no dash warning lights" do you mean:
    1. I turn the key "on", and there are literally no lights "on", not even the alternator warning light,
    or
    2. I turn the key "on", and the alternator warning light comes "on", but there are no other oddball warning lights "on" (like "check engine")?
  6. moysiuan
    moysiuan F1 Rookie
    4,192
    Canada
    1990 t Coupe is nice!
    Sounds like one bank of the engine went down, maybe a coil or related power module failure is my immediate reaction.
    https://www.superformance.co.uk/348/ignition.html
    The ones on there can probably be tested, maybe someone can detail the procedure for a coil/module test.
  7. Fletchf1
    Fletchf1 Rookie
    Jun 29, 2018
    8
    Banbury
    Christian Fletcher
    Answer to Steve; #2, there are no oddball warning lights on the dash, just ign and oil I think, the usual.
  8. Fletchf1
    Fletchf1 Rookie
    Jun 29, 2018
    8
    Banbury
    Christian Fletcher
    Answer to Moysiuan; does anyone know how to test the coils using a multimeter?
  9. Wingnut
    Wingnut Karting
    Feb 11, 2005
    155
    Corolla, NC
    A coil went bad on my 1990 t. Similar engine problems, one bank not firing. RockAuto had Bosch replacement coils for @$60 each as I recall. Check out my post on coils for the Mondial t here on FerrariC
    Wingnut
  10. Fletchf1
    Fletchf1 Rookie
    Jun 29, 2018
    8
    Banbury
    Christian Fletcher
    Thanks for all your helpful replies.
    I found the problem today.
    Left bank had no fuel supply so checked the pump relay on the rear bulkhead in the boot. The fuse had blown. All fine now.
    JLF, gsfent and moysiuan like this.
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,678
    Argent/Brasil
    Guido
    Time to find out why that fuse did blow...
  12. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    was going to suggest this. Always start with the simple stuff. Verify fuel supply, spark then if those exist move on to more complicated stuff. Glad you found it.
  13. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,481
    Menlo Park, CA
    Paul Chua
    Hmmm, could also be bad fuel pump too, that’s what happened to me when I ran half engine.
