Mondial T timing belt replace | FerrariChat
Discussion in 'Technical Q&A' started by JackFB, Aug 28, 2021.
  1. JackFB
    JackFB Rookie
    Aug 28, 2021
    2
    Poland
    Jacek Franciszek
    I need your help, I'm new here but I see that many experts so I'm counting on help.
    I bought a Mondial with about 20000 miles, the timing belt was replaced in 2012, since then the car has been driven about 1000 miles and has been stored in collection. I have changed the oil and filters, but should I replace the timing belt immediately? Sorry for any mistakes))) , I am from Europe )
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,467
    San Carlos, CA
    Mitchell Le
  3. tazandjan
    39,086
  4. Glassman
    Glassman F1 World Champ
    I won't put 30K on my car in my lifetime. After buying the car I went 14 years to the first belt change because I didn't know any better. Pre internet!!!!
    I'm at 5 to 7 years right now.
  5. lopena
    lopena Formula Junior
    754
    Jacek:
    Yes...get those timing belts changed soon, along with any worn accessory belts and hoses. I change my timing belts every six years (the old belts invariably still look good after six years).
    Also check for old, brittle fuel lines while you’re in there.
    Find yourself a competent independent mechanic (stay away from the dealership). This is not a complicated or difficult job...I paid $1,000 to have this done recently on my 328.
    Also have the mechanic check your four motor mounts...if they’re original they probably need replacing at this point...again, not a difficult job but the mounts themselves are expensive ($250 each here in the U.S.).
    It goes without saying that you should also flush the cooling system and the brakes if you have no idea when that was last done.
    Next, give your car a comprehensive safety inspection including suspension and tire date-codes. Inspect your sparkplugs.
    Finally, get yourself a good fire extinguisher and/or a couple of Elements fire sticks.
    Once you’ve taken care of the above items you’ll be ready to enjoy many years and miles of driving fun!
    Good luck!
    Alan
    N.J.
  6. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    431
    Eastern Tennessee
    Howard Scott
    Changing the belts on a Mondial T is a hell of a lot more complicated than on a 328. The motor has to come out of a T for this job. The 328 you can do it through the wheelwell.
  7. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,988
    Atlanta, GA
    Steve D.
    Exactly. Like the 348, expect a $5-7k USD bill (to start), but I see you're in Poland?
    sjd
  8. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    388
    Herts, UK
    Richard
    And don't forget the tensioner pulleys whilst your in there.....
  9. lopena
    754
    Jacek:
    There’s a tutorial on this website somewhere on how to change timing belts on a Mondial T without dropping the engine...it involves removing the fuel tank to give you more room (I frankly don’t know how easy or hard that is to do). Use the Search function (the magnifying glass above) to find the thread.
    Maybe someone here who has done this can chime in?
    That being said, you may want to drop the engine anyway so you can easily get to the fuel lines, coolant hoses, motor mounts, etc. It’ll also give you a chance to clean and detail the engine compartment.
    Many of us here use “Hill” tensioners on the timing belts...again use the Search function to learn more.
    Keep the questions coming.
    Good luck,
    Alan
    N.J.
