Mondial T transmission fluid change? | FerrariChat
Discussion in 'Technical Q&A' started by GTSRacer, Nov 2, 2005.
  1. GTSRacer
    GTSRacer Rookie
    Aug 12, 2004
    32
    Hampton, VA
    Olivier F. Raoust
    Help! I'd like to change the tranny fluid in the T, and no problem draining it but where exactly is the filler plug? Do I use the little dipstick bolt on the side of the transmission? And if so, what's the easier way to get to it?
    If not that plug, is there an filler plug on the top of the transmission? That would mean removing the airbox assembly I assume.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Correctomundo.
    You will need a very big allen socket for the filler plug on the top of the trans. I forget what the actual size is, but it's a big one.
  3. GTSRacer
    GTSRacer Rookie
    Aug 12, 2004
    32
    Hampton, VA
    Olivier F. Raoust
    Thanks Ernie, that helps! BTW, do you know how many quarts the tranny takes? 4 or 5?
  4. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    4
    Actually it's 1.06 gallons (4 liters). But just put in 4, cause 100% of the oil doesn't come out when you drain it. Use a 75W90 trany oil.
  5. GTSRacer
    GTSRacer Rookie
    Aug 12, 2004
    32
    Hampton, VA
    Olivier F. Raoust
    Good info, thanks > yes, I only use Redline 75/90
  6. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    That's right, it sure is big. I made a tool by welding a nut onto a long 12mm bolt (19mm across flats of head) - worked perfectly when combined with a standard 19mm socket and extension.
  7. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Well that sure was innovative.
