Mondial Wheel Rebuild | FerrariChat
Discussion in 'Mondial' started by BOKelley, Aug 22, 2009.
  1. BOKelley
    BOKelley Formula 3
    2,351
    Au'n Colorado
    Brock
    #1 BOKelley, Aug 22, 2009
    My Mondial came with 17" HRE three piece wheels that looked sharp at first glance but the improper offset, made the vehicle look a bit odd. I learned that the car had 2" lips and 6" barrels up front and 3" lips and 6" barrels at the rear. I contacted HRE to see if the wheels could be rebuilt, but they told me all they could do way shift the offset inboard 1/2 inch.
    So I shifted my search to Ebay to look for wheels and stumbled upon someone selling various parts and pieces for 17" HRE's. He had two pair of 1" lips and a pair of 7" barrels that I snapped up. The plan was to reduce the wheel widths to 7" up front and to 8" at the rear. This would shift the front wheels inboard by 1" and rear 2".
    The R&R process was fairly straightforward and within a day I had all of the wheels put back together and sealed with silicone. The tires that came with the car then went back on....235 45R17's up front and 255 40R17's out back.
    Big disappointment arose when I looked at the new set up with wheels and tires back on the car. At first I couldn't put my finger on the problem...but it seemed to stem from the front wheels which now looked odd. So I found a couple of tire size calculators online to dig into the issue. I started by looking at specs for stock 205 and 225 55R16 and was somewhat surprised to see that the front tires are of smaller diameter than the rears by 0.8 inches.
    That became a bit of a "duh" moment because when one thinks about it, yes the front and rears will be of different diameter when the widths are different but with the same profile. So it became obvious that the problem was with the 235 45R17 up front...they were actually a third of an inch larger in diameter than the 255 40R's in the rear.
    Today I purchased two new 235 40R's for the front which gave me tires that were 0.6" in diameter smaller than the 255's in the rear...basically a similar differential to stock. I had wanted 225 40R's up front, but only one manufacturer supplies tires in that size for the street.
    As an added benefit, the car has now been effectively lowered by about 1/2" in front and 3/4" in the rear as compared to stock. Wheel arch rubbing is also completely eliminated.
    The first image below is the "as received" look....the three following show the re-shod look.
    Brock
  2. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Very Very nice looking.
  3. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    Mon Dieu - what a difference! The first shot looks really bad - just so wrong - but the new look is perfect.
  4. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #4 finnerty, Aug 22, 2009
    Indeed !
    The original set-up was sporting an awful lot of rubber and wheel track for a car with a nearly double-digit (downhill) 0-60MPH time!!!!
    Just teasing! The new wheels and the car look terrific!
    But, we all know the "Mondi" is not the fastest horse in the stable :)
  5. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Nice job! Great write up. Super photos. Car looks fantastic.
    Well... That all depends on which kind of Mondi it is.
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Well done, sir!
  7. effer
    effer Formula Junior
    Jan 6, 2004
    814
    near Montréal
    François R.
    Well done! Now you will be able to push this horse faster and realize that it belongs to the right stable! :)
  8. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    So what? Was it designed to be? No. Does what it was intended to do very, very well for a car of the period.
