News
Mondial window motors
Discussion in 'Mondial' started by steviep6, Mar 7, 2006.
  1. steviep6
    steviep6 Rookie
    Mar 7, 2006
    7
    new york
    steve psaila
    Anybody have any fixs for a dead window motor in my Mondial Cab? Passenger rear motor bad-will another motor bolt in? FNA wants $900.00 for a new one !! Thanks.
  2. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,535
    Suffolk, Uk
    Pete.G By The Sea
    Click on search at the top as there are several threads with reference to this, Mondials are notoriously slow and I have heard of cases where new motors have been fitted and made no difference
  3. No Doubt
    No Doubt Five Time F1 World Champ
    May 21, 2005
    59,396
    Vegas+Alabama
    Mr. Sideways
    Hetek has a great "how to" on fixing that window motor: http://www.ferrarichat.com/forum/showpost.php?p=135373569&postcount=14
    FYI, it is a standard Bosch motor (found in countless cars). You can find it used on eBay or have it rebuilt (or re-wired to make it run faster) for $50 or less. It just unbolts from the window assembly.
  4. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,731
    CA
    Jerry
    Setting the cables back up correctly is a biatch! I kinked mine during the process & had to buy a new part & then left it to my mechanic to re-install.
  5. steviep6
    steviep6 Rookie
    Mar 7, 2006
    7
    new york
    steve psaila
    Thank you-We've got a couple of 55 degree days coming up this weekend, I'm going to get on it.
  6. racespecferrari
    Jan 31, 2006
    7,535
    Suffolk, Uk
    Pete.G By The Sea
    Have fun, Its snowing here in the Uk :-(
  7. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    Any chance you know the Bosch part# .. .. I need to replace my rear window motor ..
    Regards
    Thorsten
  8. stekkefun4
    stekkefun4 Formula 3
    2,135
    Belgium - Europe
    I have a couple of spare window motors on sale in the parts section. Working great, but keep in mind that the problem is mainly caused by hardened grease around the moving parts and that has to be removed and treated with new grease.
  9. No Doubt
    May 21, 2005
    59,396
    Vegas+Alabama
    Mr. Sideways
    #9 No Doubt, Jul 1, 2009
  10. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    Great advice! Thank you very much!
  11. No Doubt
    May 21, 2005
    59,396
    Vegas+Alabama
    Mr. Sideways
  12. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    #12 AR!, Feb 24, 2010
    My rear window motor wasn´t of the BOSCH type. Presumably Magneti Marelli. Anyway, I found a spare motor and I'm in the process of replacing the old one.
    Here are some photographs, just in case they could be helpful for someone else with a broken unit from a t. I will report again as soon as the fixed unit is back in place.
  13. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    Check the voltage at the window motor when you press the window button. My voltage was 6 volts. I used DPDT relays with a fused hot wire. Do a search it will show the procedure.
  14. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Where did you get the DPDT relays? Brand name, model? Thanks in advance.
  15. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    #15 AR!, Feb 27, 2010
    Thanks a lot for the hint! In case anyone else in interested in the thread mentioned, I guess it it this one: http://www.ferrarichat.com/forum/showthread.php?t=229991
    The source can be found in the thread mentioned above (post 22).
  16. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
  17. AR!
    AR! Formula Junior
    Apr 8, 2004
    974
    Berlin, Germany
    It's done.
    List price (Ferrari) for the complete unit: ca. 1000 EUR but unobtainable on this planet
    Price for the used spare motor: 25 EUR
    I didn't manage to find the FIAT type for the complete assembly. But it seems the window motor itself has been assembled in millions of FIATs, so finding a used replacement motor is pretty easy.
