Mondial window question.. | FerrariChat
Discussion in 'Technical Q&A' started by mg54, Mar 3, 2011.
  1. mg54
    mg54 Rookie
    Jan 12, 2005
    48
    Massachusetts
    Michael Gardner
    I have an 85 Mondy qv with the wire cable window lift system. (awful). I recently found out that the 85 Mondy 32 has a mechanical lift.
    Has anyone converted from the wire to the mechanical lift...I believe the door is the same..
    MG
  2. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I never knew there was a different option. I'd heard the cables work fine is everything is properly cleaned out and lubricated. Including all the electrical connections along the way.
