Mondial Windscreen Washer Pump Relay and Fuse? Location | FerrariChat
Discussion in 'Mondial' started by aleib, Mar 17, 2023.
  1. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    Hi,
    my mondial 3.2 windscreen washer stopped working.
    set 12v directly to the water pump and it works good.
    set a multimeter in the wires to the water pump and it does not receive anything
    when I turn the cabin knob, I can clearly hear a relay clicking, so the knob/trigger for the washer pump is good.
    the issue is most probably the relay (that I can hear), a fuse if any, or the wires... nothing more.
    where are them?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    From the wiring diagram it appears to only have a fuse, 2 nd in from the right hand side. Its a 15 amp and also supplies windscreen wiper and reversing light.
  3. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    well i'm 100% there is a relay, because I can hear it :)... i will ask some help
    there are 3 relays under the dash, are these in any diagram?
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Do the windscreen wipers work ok ? Long time since i had mondial- the screen wash is on the wiper stalk ?
    The wiring diagram does not show location of other relays, only those in the fuse box
    You should have a grey wire with a red stripe to the washer pump, look for this on the pump on switch
  5. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    yes wipers work... only the water pump does not... and it has a relay, its not directly to the knob!
  6. afterburner
    afterburner F1 Rookie
    3,456
    Switzerland
    Urs STEMMLER
    Yes it is. Unless someone added a relay.
    The ones below the dash are HVAC related.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Glad you said that as i did not know what they were. You would not need a relay for such a tiny pump- it must have been modified as diagram shows switching from a contact on the stalk
    afterburner likes this.
  8. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    This is the relay, and it's a crossed one!
    Just down the wiper timer.
    You can test it easy, just remover that relay and try the water pump...
    I switched the relay with another, but still no luck... It could be the wires or the fuse box or the plugs... Kill keep You posted
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    That relay set out is different to my book, send me an e mail address and will send you some info
  10. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    I can understand that, but can You test? Just remove it and test, the water pump Will not work, confirming thats te relay (the one that is not in the picture ) Also the fusebox sticker says it's te wiper relay...
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    The drawing does not show a pump relay, i can send you wiring diagram so you can follow the power supply circuit
  12. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    I fallowed it, and it goes to the wiper timer and to that realy
  13. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
  14. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
  15. afterburner
    3,456
    Switzerland
    Urs STEMMLER
    There is NO relay in the pump circuit.
    There is a relay (the black box) for intermittent wipers.
    There is relay for the switching between the 2 different wiping speeds.
    If you are actually interested in readable diagrams, message me :)
  16. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    More interesting finding, the earth for that relay is actually the positive of fuse 23 (the wipers fuse)... This is bizarre!! I think I see where all this is going ... The fuseboard is corrupted or something very oscure and nasty was implemented for some logic hahaha
    Usually ground of relays go to battery negative, not positive ...
  17. afterburner
    3,456
    Switzerland
    Urs STEMMLER
    I can supply you with a readable diagram.
  18. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    One thing is sure: + for the pump goes to pin " 3" of that conector and pin " 5" of the wiper timer, so i think there is something goin on in the wiper timer itself that is holding the pump to start
    The wiper pump goes to pin 3 i can confirm with the tester and the wire colors, its a grey with doble red one! And it's not the knob wire colors.
  19. afterburner
    3,456
    Switzerland
    Urs STEMMLER
    Shooting in the dark is fun, isn't it?
  20. BrandonDIS
    BrandonDIS Rookie
    3
    Brandon
    It may be that the fuse has burnt out. Please check the condition of the fuse
  21. afterburner
    3,456
    Switzerland
    Urs STEMMLER
    Nope - he said the wiper works. Same fuse for wiper and washer.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    If there is power to the stalk and the wipers work, the pump supply looks to be a switch off that. Vis the gray wire with red stripe
  23. Alden
    Alden F1 Rookie
    3,385
    Central Florida
    I just want to thank After Burner for all his work on doing modern colored diagrams of the electrical systems on our cars, his fuse box diagram even has the part numbers to upgrade the modern relays
  24. aleib
    aleib Karting
    Oct 12, 2022
    127
    Alejandro Leib
    Issue fixes, the pump motor was stuck/jammed and the conector 3 in the plugs was carbonized/corroed... Now it works, i just cleaned and sanded the terminal and ser the motor in reverse polarity and back a few times and started running again :) the click i hered was probable the short/carbón/spark/release
  25. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Open up the stalk and spray the switch connections with contact cleaner
