Hi I just removed my '92 348tb right side oil cooler radiator. It had a small leak. It appears that a previous owner kissed a speed bump with the bottom of the oil cooler locating pins (that protrude below the bodywork). The hit bent them rearwards and as a result twisted the bottom plate of the cooler just enough to cause the leak. Watch out for those curbs and speed bumps! Although the coolant rad from the right side is not leaking, but since it's out of the car, I'll have it cleaned & pressure tested as well at the same time. Does anybody know a reputable place in greater Montreal that understands Ferraris and does perfect (or near perfect) oil and coolant radiator repair? Thanks in advance for any advice. Richard
i know that auto bugatti http://www.autobugatti.com/ near the dorval airport does work on ferrari's and other high end cars....i believe they are factory certified as well, so it's worth checking out
They are Ferrari of Quebec's "certified" body shop only....not for service. However, Joe V. does fix Ferrari's and all types of other great cars.
