More 308 brake madness | FerrariChat
Discussion in 'Technical Q&A' started by Martin Meade, Nov 16, 2006.
  1. Martin Meade
    Martin Meade Karting
    229
    B'ham, WA
    Martin Meade
    #1 Martin Meade, Nov 16, 2006
    In my never ending quest to drive myself to drinking...
    For those who are planning really big brake kits for 308's because of these new motors being put together ie stroker, supercharged etc, I wanted to know the actual pedal mechanical ratio. Boosters don't work too well on low vacuum motors anyways. It becomes very important to know this if you are planning to eliminate the booster and run dual masters. Important I guess if you plan on engineerig the system as opposed to throwing stuff together.
    The pedal box on the 308 is a nightmare of levels and contraptions designed to turn the booster and MC 90 degrees to the pedal centerline. Previously we eyeball measured and calculated because we never had one out of a car. I found this little gem on the shelf over at Ferrari service of Costa Mesa (now of Irvine). Micheal was nice enough to let me borrow it.
    Here is what I did. I disassembled the booster from the pedal box and put two dial indicators on it to measure actual input distant vs. output distance.
    Turns out it is EXACTLY 4 to 1. So there.
    Please paypal all beer fund donations to sales@************.......
    Martin
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Nice work. :)
  3. Rifledriver
    37,126
    But I only brake at the extreme bottom of the pedal so my ratio would be higher.
    I'll take a Margarita at Monterey next year.
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    hand built by craftsmen remember........
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    #5 mk e, Nov 16, 2006
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Holy COW those are big rotors. Now you don't need WHEELS!
    Same bolt pattern?
    Birdman
  7. Ricambi America
    Sponsor Owner
    Brakes are for losers.
    A tire wall or Armco will stop the car much faster, and with less wear on the pads themselves.
  8. Martin Meade
    229
    B'ham, WA
    Martin Meade
    This was a fluke to be sure... it was measuring out to one or two thou...
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    The rotors are a brembo something with custom hats I bought 3 or 4 years ago and haven't gotten around to installing...figuring brakes only slow you down anyway. I'm installing a new ecu and adding traction control so I need to add wheel speed sensors. I figured now was finally the time to get the rotors on the car.
  10. Martin Meade
    229
    B'ham, WA
    Martin Meade
    Yes, but, don't forget your Bozo the Clown shoes push your contact point with the pedal farther up, effectively giving you a 3 to 1 ratio...
    mk e, you can put anything on anywhere, you just need the master cylinder volume and pedal ratio to make it right. The stock master will not support the piston sizing in those calipers, they have very large total piston area. On the bright side, you'll never have to worry about the rears locking up prematurely ;-)
    Martin
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    Yeah, I haven't done the piston math yet...next step. I've got match rear rotor, I just don't have calipers yet...I'll find something
  12. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    LOL! Your story reminds me of my last visit to the Ferrari factory. That was a few years ago. They were assembling the 360 Modena's gearboxes with gears coming out of boxes labled "Porsche".
  13. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    So Mike,
    I t looks like these are about 355 mm, or so rotors?? Killer calipers even if they have cursed labels from the dark side.
    I just happened across a Chevy Silverado big brake kit by Brembo that uses 355 rotors and 40-44 mm pistons, (F-50 brakes) 7000 miles on 'em and $700.
    No pretty hats or caliper brackets yet but Martin and I are working on it as we speak.
    Will probaboly go with 360 calipers and 330x28 rotors onthe back - I know it is too much but we are hopeing to work it out. Martine is pretty cool, maybe i should contribute to his beer fund :)
    Now if i can only find a tandem master cylinder big enough....
    We are cookin' now,
    chris
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    Yes, 355mm x 32mm
    [quote}
  15. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Martin, that is crazy! The more i see what Ferrari did on these older cars, the less enamored i become.
    BTW, may have another custom job for you concerning brake bits. Will send you an e-mail in a week or so.
  16. BigTex
    79,386
    Houston, Texas
    Bubba
    308 brakes ARE the same as P cars of the same era, IIRC.......AFAIK.
    Same weight parameters........
  17. BigTex
    79,386
    Houston, Texas
    Bubba
    ....and 4 to 1 is a GOOD ratio, if you are in a bar! ;)
    Jesse Dayton at the Continental Club Saturday....
    I'm buying! C'mon everybody!
  18. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    I believe they've been doing that since the 246. My conspiracy theory is that the cranky synchros on second are a Porsche sabotage attempt :)
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    Here's a question about proportion valves.
    If the front does say about 60% for the braking and the rear 40% is the right answer to size the pistons/rotors to make the inherent ratio of the system as close as possible to 60//40 ? Or do as the factory did and install over size rear brakes and then get the balance the system with the proportioning valve?
  20. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    you need to consider other dynamics too... you're making massive changes to the unsprung weights in a negative direction... so if you're just tearing up 1/4 miles, so what, but if you intend to go around corners/over undulations etc, you should consider that..
    you'll only stop as well as your tyres will allow, it's repeatability that's your major gain, with just a very small gain from the brakes themselves.
    Plus, big braked/powerful/slick tyred 308's will distort their control arms in the end... you should consider tubular/fabricated arms for extra strength or you'll simply rip the bushes/welds out of them....
  21. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,312
    Ventura, California
    Robert Garven
    or dont destroy a perfectly good 308 and buy a challenge car?
    JM2¢
    Rob
    whose still using incandescant bulbs & points
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    Actually, the new big brakes are lighter than the OEM stuff. They have more rotaional inertia due to the diameter increase, but the hp due to the boost inceas should more than off-set that :)
    I've had some trouble with over heating the brakes, so I am installing basically exactly what ferrari did to solve the problem on all the newer models. I could probably live with a bit less, but I didn't want to have to do it twice.
    That's on next year's list
  23. Martin Meade
    229
    B'ham, WA
    Martin Meade
    May this post go down in history!!!!!!!!
    Read very carefully. There is no mystery to a prop valve. In it's simplest form it is a spring in a block, that when a certain pressure is reached, the spring is overcome and fluid pressure gets reduced at a constant rate compared to the front. Adjustable ones change the spring pressure. It DOES NOT balance poorly selected components. You are not reducing pressure to the rear until that pressure is reached.
    Imagine, if you will, a car with brake calipers/rotors sized to provide just the right amount of torque to avoid lock up at full forward weight transfer under track conditions. This is what real race cars do, the prop valve, and frequently the balance bar, is for tuning WHILE racing to adjust for fuel load, changing track conditions ie rain, dirt etc. One catch, a race car is rarely using brakes less than at maximum(if so, you're getting passed!). A street car set up this way would never have to replace rear brakes because the front is always doing all the work. We want the rears to work as hard as the fronts(given the weight on the wheels) to have maximum brake capability. Tires stop the car, if 2 tires aren't working you're not stopping as well as you could be.
    The old school way of doing this in production cars was the prop valve. Engineers would test the system, finding the point the rears would lock(from weight transfer) and set the knee point of the prop valve to somewhere before that, attempting to have the correct pressure show up at max braking/max weight transfer. The knee point is the pressure that overcomes the spring and causes rear line pressure to be reduced, typically at a 3 to 1 ratio. I am not aware of any valves that adjust the rate, only the knee point. As these systems got more sophisticated, they put levers on them that were attached to the rear chassis somewhere and would further tell the prop valve how high the rear of the car was getting. A little cam inside the valve was actuated by this lever further tailoring the system to the given conditions. I have heard mention of some that acted like a level, and when the level was tilted forward it changed the settings as well. Finally, all of this was done away with when Electronic Brake Distribution (EBD) came about and all pressure reduction is handled by wheel speed sensors, ABS and stability control algorythms.
    Where does that leave us? It is entirely possible to design a system with rear components so large a prop valve won't even keep the rears from locking before the fronts. This leads to spectacular spins. Not cool. Production cars are always designed to be slightly more forward biased than optimum, so as to never induce this condition. Bumps in the road, new tires in front with worn out ones in the rear, different pad compound front to rear all have to be accounted for by the factory. If you are setting up your street car into a race car, there are typically gains to be found in bumping up rear brake torque. The amount can only be found through testing different components in the conditons the car will see.
    It is possible to tune brake torques with pad compounds, in fact these have the biggest (and easiest) effect on brake torque. You just better pick compounds that have similar heat/friction curves or you will have some surprises! The best is to always start with the factory bias and the same pads front to rear. Straying from this is OK, you just have to be willing to dedicate time to experimenting and testing.
    So what can I do with this box of Ebay stuff I bought that now doesn't look too good? Dual masters and a balance bar. The different masters put different line pressures front to rear(or however you have them hooked up). The balance bar fines tunes this further. You still want your prop valve, you still have weight transfer issues, we didn't change the laws of physics! Make sure to remove your stock valve if you are using an adjustable one. Ultimately we are trying to maximize component life and provide line pressures that keep all wheels braking to their fullest capacity for the weight on them.
    I have left out alot, and hopefully not confused you. There are so many scenarios to consider, towing a trailer going down a mountain pass, emergency braking in a hairpin, straight line max decel, manufacturing and engineering expense... EBD is really a quantum leap from the lowly prop valve.
    Now change your ride height, move the battery or fuel tank, shift the engine location, anything that moves the location of the CG and return to step one.
    FWIW
    Martin
  24. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    As always, excellent advice!!! FYI guys with 308 Brembo front and stock rear... try the stock brembo DS1100 front and Ferodo DS3000 rear (available from Girodisc of course). Also, upgrade rear rotors to Girodisc slotted (and front slotted when you can).
    i'd throw it out, brakes ARE NOT the thing to splice and dice and <cough> creatively engineer <cough> by the less than KNOWING guy. But hey, that is just me. My life depends on those brakes when doing 90+mph going stright towards the wall at turn 3 at NHIS or how about at the bottom of the downhill at the laces of the boot at WGI...
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,750
    The twilight zone
    Thanks, Martin. I've never had a proportioning valve apart or even thought that uch about it...I had it in my head it worked across the board.
    Even with ABS and an EBD they must be desinging the system to be inhearently stable aren't they...sensor,wirs and everthing else to fail?
    Are EBD valve available?...hmmm, I wonder if the motec can run one....
    The fronts I have have almost the same piston area as the 36/40 brembo they sell as a bolt-on, so I'm guessing I can do something with them...although I discovered the pads are too wide for my rotors, but it looks like Brembo has other pads that I can install to solve that.
    My plan is to track down a set of rear calipers with pistons that will balance the fronts I already have, then find a mastercylinder that will work with both. I like the thought of dual cylinder with a balance bar, but I keep thinking I would like to have a spare tire again and I know I like power brakes...I guess with some creative work I could get the dual cylinder in and the power brakes aren't that important......
