More 348 and 355 questions | FerrariChat
Discussion in '348/355' started by mrpcar, Jun 8, 2007.
  1. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Sorry about more newbie questions, I did a self intro post in the general discussion area several weeks ago. Been a long time Porsche owner, currently still own a 96 993 and a 99 996. The 993 is getting very little use, so I thought that would be a good canidate spot for an used Ferrari. So basically the 996 would still remain as my daily driver and the Ferrari will be the weekend fun car.
    So far based on all my reading and research from this forum I am set on either a 348 or a 355. But my budget is around $70k, so I can either buy a late model 348 and a early model 355.
    From my reading everyone seems to be complaining about the 30k service on the 355 "Drop engine replace belt", but from what I have read that's the same for the 348, right? 30k or 3 years?
    What about valve adjustments? Are either engine with hydraulic lifters? Or does it require valve adjustments?
    I would have to say the only thing I don't like about the 348 is the rear grill and the rear lights, other than that I have no problem with the look.
    TIA
  2. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    One word.............. Brotherhood
  3. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    Yes the 348 needs belts too, the good news is that you will not need valve guides or exhaust manifold like the 355. Neither cars use hydraulic lifters, adjustement is accomplished through shims although it is rare (just did both my cars one with 35K miles and the other with 55K and neither needed adjustments).
    348 is a simple car mechanically, easier to work on than the 993 and far more engaging driving wise. I had 97 993 that I used as a daily driver; good robust car, great for track work and easy to drive at the limit. 348 requires more attention and is much sharper and raw, the 355 is similar but less edgy and more refined. Both have a sound at redline that makes the Porsche flat 6 sound like a lawn mower ;)
    You can get a very nice 348 with service in the $40K+ range, and a Spider for $50-60K. Drive them and you will like them; I thought they were such good value that I bought one of each. BTW, my daily driver is no longer a Porsche but another 2+2 that is the best value on the planet - 01 456M GT 6sp - drive it and you'll get rid of your 996 in a heatbeat!
  4. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    Funny I was in your exact same boat, been a porsche owner since 99, still have my 2003 C4S as a daily driver. I also was looking to spend no more than 70K for the 1st year of ownership. Give that the major service to change belts etc needs to happen every 5 years or so, and costs 6-10k depending on who does it and the model (355 is slightly more), you have to factor that in. In this price range you are looking at early model 355s (95-96) and apart from the major service you need to figure out what if anything to do about the valve guide issue if it has not been fixed or addressed in the early model car. That could go from spending $0 since some cars apparently run fine, to spending a lot of money to fix the valve guides during the 30k.
    Bottom line, I came to the conclusion that it would take a long time to find a 355 that had either a documented recent major service and valveguides done for $70k, or had neither done and was $60K or less and in good condition. Not saying it isn't out there, but it is not easy to find. All the cheap 355s I called on left me feeling queasy for some reason or another.
    So I joined the 348 brotherhood. I bought another Fchatters car for mid/low 40's, bought 355 wheels/tires for $2700, I am budgetting $8K for the major service and another 2K-3K for things like floormats, spacers, shields, fixing sticky interior, 02 sensor replacement etc, maybe hyperflows. That puts me at a total of $55K for a what will be a great 348, vs 70K for what would have been a so so 355.
    Just my opinion,
    -Eric
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Flawlessly logical. LOL :D
  6. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Ok, looks like I am set on getting into this brotherhood thing, just got off the phone with Chris (VTC), and looks like I am going to shoot for a 348.
    Thanks!
  7. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    #7 VTChris, Jun 8, 2007
  8. f355spider
    f355spider F1 World Champ
    18,053
    355's do not require valve adjustments. Valve guide replacements on occaision....but not valve adjustments. ;)
  9. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    #9 vvassallo, Jun 8, 2007
  10. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Another question about the belt, I assume this is the timing belt which drives the cam shaft, when this belt breaks supposely the valves will drop, will it hit the piston?
    What about other belts?
    It says to replace the belt once every 3 year or 30,000 miles, for a 1990 car should the belt have been replaced at least 5 times already?
    What's the typical cost of the timing belt replacement?
    Thanks for putting up with my newbie questions.
  11. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Chris,
    How long did you have the car off of the charger for that picture? You know that can be dangerous... Better get it back in the garage! :):):)
  12. tjacoby
    tjacoby F1 Rookie
    Nov 1, 2003
    2,857
    Vancouver Canada
    tj
    yes - the 348 is an interference engine, snapped belt = 32 valves clangin' away. 355 has two cam belts, a snapped belt only has 16 valves dancing.
    FNA does say 3 years and 15,000 miles, my mechanic says 30,000 miles is fine. The manual says 52,000 miles if I recall. This is a very hotly contested discussion point on Fchat. You will find some cars that have NEVER had their belt changed, and some that have had valves dancing already. It's all extremes, of course. I'd budget for $5-6k USD for a belt change with extras, but could be higher depending what else you want to do at the same time. I haven't had to go through this yet. A lot of optional stuff gets done to these cars while you're in there.
    My mechanic seems to be re-adjusting the tension on the accessory belt each time he gets the car for a few days, or whatever he calls it. I believe those are the only two belts.
    I've had a few little things fail on my 348 - but I drive her a lot ('94 spider). Currently have an e-brake issue to work through. Only the throw-out bearing on the clutch was a real issue - and that was in the first few months. I really like my 348 and have no interest in moving to a 355 or 360, regardless of how prices move in the next few years.
  13. VTChris
    Aug 21, 2005
    13,259
    GCalo splits, and now you harass me ? :D :D :D
    OH, btw, it was still plugged in ;) Photoshop does wonders
  14. Llenroc
    Llenroc F1 Veteran
    5,521
    Colorado
    Vern
  15. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
  16. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Hummmm..... Nothing special... sounds like my Porsche 993......
    :p Just kidding, not even close. Make my 993 sounds like a sewing machine.
  17. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    Vince, the car looks really stunning - PM me next time you've got it at Gary's or in San Diego.
    I think you got good advice here already.
    For $70K, I'd agree you could get an exceptional 348 instead of scraping into an low-end 355. I also think it's good to keep the 996 as your daily driver - Ferrari service tends to take longer than with normal cars. Usually a good shop can get parts overnighted, but the odds of everything being nicely stocked on a shelf in the back room aren't high.
    Of course I would try to talk you into a 328, but seeing as this is the 348/355 forum I won't even mention it.
  18. VTChris
    Aug 21, 2005
    13,259
    #18 VTChris, Jun 9, 2007
  19. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Dude,
    I went to their site, awesome pics! Dude, you are killing me, please please help me find a RED 348 or 355!!!!!
    And the best part is they are only 15 minutes away from me!
    Do you know if they have any cars for sale?
  20. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Without question, go with a 355 when possible. You'll regret not doing so IMO. Better styling and performance, and not much to worry about if maintenance is current. Just don't buy a neglected car and expected to easily sort it out.
    Not too far from you: http://www.ferrarichat.com/ferrariads/showproduct.php?product=2578&sort=1&cat=11&page=3
  21. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I don't get it, at 19xxx miles, it had new clutch? Softtop overhauled? Leather seats and dash redone?
    In any case, I think it may be worth a call, I was really looking for a Berlinetta, but the wife would like a spider..... Guess who will be complaining and ask to put the top up first.....
    Thanks for the lead
  22. TopElement
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    One these cars, most maintenance is done due to age and not miles. Would you want to use a 10 year old clutch?
    The dash leather shrinkage is a known problem, and doesn't happen again after it's fixed.
  23. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    I see, that makes sense.
    Stupid me just noticed that is your car. LOL! Already sent you a PM, will send another one with my phone number.
