More 355 Belt service questions | FerrariChat
Discussion in 'Technical Q&A' started by tiara4300, Apr 5, 2007.
  1. tiara4300
    tiara4300 Formula Junior
    Feb 27, 2005
    650
    miami ,fl.
    Adam
    I'm preparing to do the belt service on my 355 and have a few last minute questions before I dig in. I have the factory repair manual but there are a few questions I still have not sorted out. Any tips or photos are appreciated. I know many of us would just send it over to the dealer, but I have a complete shop at my disposal and prefer to do the servicing myself.
    1. Is there a cam locking tool for this specific task , or has anybody fashioned one themselves? any tips here are appreciated.
    2. How do you set the belt tension once the new belt is on.
    3. When changing the crank seal can you reuse the crank bolt?
    4. what are some othere tasks to carry out while the engine is removed. I already plan to replace all cam seals, crank seal, tensioners,pullys,water pump, clutch and most likely exhaust manifolds. (any suggestions on the manifolds)
  2. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    943
    Europa
    Bob
    Do a search for posts by CHAA. 101 uses for a pair of lock grips.
    CHAA, hope you come back here dude... we need you.
  3. tbakowsky
    Sep 18, 2002
    20,018
    The Cold North
    Tom
    1. no cams must be degreed. You can fashion a cam locking tool easily from bits and peices you probably have lying around the shop.
    2. Use the Cavis belt tension gauge, or a steager gauge, spec is in the service manual.
    3.yes you can reuse the crank bolt. Use the recommend thread locker in the service manual or LocTight blue
    4. Check everything!! and replace as needed. Thow a new t-state in there aswell.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yeah,
    If you still have the stock exhaust manifolds send them out to get ceramic coated.
  5. tiara4300
    Feb 27, 2005
    650
    miami ,fl.
    Adam
    thanks for the suggestions, keep em coming. Can the old manifolds be freshened up and coated?
  6. windsock
    windsock Formula 3
    1,160
    It appears someone stated no need to time the cams if locked in place, unless I missread the response. 355 in particular are very sensitive to the camshaft timing. Idle quality, emissions and premature catalyst and manifold failure will all likely occure if it is off even slightly. the cam timing should be +- 1 deg. from specs. spend your time doing it the first time or you will be replacing other parts and taking the engine out to perform the service again and correct the timing.
    Best of luck.
  7. tbakowsky
    Sep 18, 2002
    20,018
    The Cold North
    Tom
    I assume you are refering to my post. I forgot the comma after the word "no". In other words..."No, the cams MUST be degreed"
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    This is interesting because I just spoke with the local Ferrari dealer and they never degree the cams when changing a timing belt.
    They also stated that you would know if the cam timing were off because the car would not idle smoothly.
    They will check if the customer insists but this is extra cost.
    My car has been dealer serviced from day one ......they checked my service history and they advised against degreeing the cams (not necessary).
    Also, they also advised that for warranty reasons their policy is not to alter the factory cam timing.....so from their point of view if you service your car at the dealer then the timing is dead on as set by the factory.
    I decided to speak with an independant ex ferrari mechanic I know and he confirmed the same story. Its a corporate policy.
    Now I guess if you service your car at the independants then you really can't be sure what someone has done or what a customer has requested be done.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    BLASPHEMY! BLASPHEMY! Arrest the heretic.
    Somebody stop rifledriver from reading that.
    LOL:D :p
  10. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Unreal! I guess that's why we find that a majority of cars that come to us from the dealer are NOT timed "dead on." :)
    And I guess that's why we find that a majority of cars that come to us from RECOGNIZED independent shops ARE timed plus or minus 1 degree (dead on, in my book).
    When I started, I didn't check or set cam timing because I didn't know how and didn't take the time to learn. Then, I had a guy work with me that showed me how. Now, we do it a majority of the time. I guess that's why people say "it's never run that good since I've had it..." after one of our services. That's also why I don't do "a la carte" belt services, either.
    Jeez, "extra cost" from the dealer to do the job RIGHT?!?!?!?
    Can't wait until Brian or Dave see this...
    -Peter
