More shifting questions | FerrariChat
Discussion in '308/328' started by klatu, Oct 7, 2009.
  1. klatu
    klatu Formula Junior
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    When I shift from 3 to 4, on occasion, the linkage hangs up. In neutral the trans seems to still be in 3. With a few wiggles side to side in the neutral slot it will let go and then the shifter will go into 4. When down shifting 4 to 3 the same. This is after warm up, and at speed on the freeway. It is happening more often now. I have read the shop manual, but it is a little vague on how the adjustments are made for this problem. There is no grinding of gears and the action is smooth once I get it unhooked.
    Rob
    81 GTSi
  2. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    Adjust your forks, easy, you need to be 2, one in the car shifting, one below the gearbox adjusting, I think there's even e video on youtube.
  3. mwr4440
    57,988
    Bavaria, The 'Other' Germany
    Mark W.R.
    It is ALSO a "While you're in there," event; shift shaft bushings, and tranny/oil pan seals. Also not hard, pretty darn cheap as F-Car repairs go, but just a bit of a PITA.
