Most 458s Discussions!! | Page 7 | FerrariChat
Discussion in '458 Italia/488/F8' started by F485, Nov 27, 2017.
  1. mikey64
    mikey64 Formula Junior
    599
    TN
    mikey
    Thanks all who have contributed. Will be trying the NVO board fix soon. Mine is supposed to arrive 3/4 from the AliExpress source mentioned above.
    I’ll work to contribute some technical guidance as I gain experience. So far other than knowing parts are expensive, this car doesn’t look like it’s any harder to work on than any of my Corvettes. Just have to be careful not to damage anything while disassembling but overall access to components looks better with removable panels.
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games” - Ernest Hemingway
  2. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    360
    Texas
    Brian
    mikey64 likes this.
  3. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    In the grand scheme of things, you are 100% right. It just feels irresponsible (for lack of a better term at the moment) to go with a 40k option when sub 20k options are for sale also. I’ve noticed all the super low mileage 458s are red with tan interior, haha. The black on black is always high mileage.
  4. phishgoldy
    phishgoldy Karting
    May 12, 2014
    115
    NYC
    To me, this is what this forum is all about. A dream fulfilled. Congratulations!
  5. pizzadude
    pizzadude Formula 3
    Feb 20, 2001
    1,282
    Indianapolis, IN
    Count me in on the camp that says 40k miles is out of control on a 458.
    Not low by any means but a good drivers car miles.
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,280
    Mel
    Jor, Cigarzman, kandi and 2 others like this.
  7. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    Beautiful representation, my man.
  8. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
  9. Melvok
    Jul 25, 2008
    14,280
    Mel
    I don't find it in Alie ....1005004402633422
  10. Melvok
    Jul 25, 2008
    14,280
    Mel
  11. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    yeah, could be that. It looks wrong…. I wonder how much to get back to red?
  12. mikey64
    599
    TN
    mikey
    Strange. That’s how I found it but now it doesn’t come up. Mine is allegedly arriving Monday 3/4.
  13. mikey64
    599
    TN
    mikey
  14. Melvok
    Jul 25, 2008
    14,280
    Mel
  15. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    That works for the 458 per the description, no? Click the last one that is the board instead of a model name
      File size:
      139.8 KB
      275
  16. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    Well boys, I finally got my first Ferrari. A 2014 458. I will make a thread about it when I pick I get it in a few days. Really cant believe I am typing this
    Stethoscope and Cigarzman like this.
  17. mikey64
    599
    TN
    mikey
  18. mikey64
    599
    TN
    mikey
    Well I have just completed my NVO PCB board replacement in the steering wheel as my turn signal actuators were not working and the start button was intermittent. Things were pretty straight forward following the two threads below and the relevant sections of the workshop manual.
    458 - replaced my steering wheel PCB with a bootleg | FerrariChat
    458 - NVO board replacement; dealer alternative | FerrariChat
    The posted instructions, as well as the WSM are slightly unclear, but the air bag module basically came straight off, no prying necessary once the two rear side bolts (T30 security bit) were removed. Getting the T30 security bit onto the bolts is a blind aim, so just had to adjust the angle of the driver until I could feel the bit securely seated in the bolt head.
    The airbag connectors have secondary locks on the top, a small flat-blade screwdriver gently pulled the tabs out and then the same flat-blade can be used to gently pry the connectors straight up and out of the airbag module.
    Also it was unclear how to remove the buttons control module, but it turns out gently pushing the back side of it from the area behind the manettino and behind the start / suspension button area will coax the 3 rubber push plugs free from their receivers inside the wheel.
    Further disassembly of the controls module was straightforward, just be gentle and patient with all the little harness connectors that go into the NVO board.
    Perhaps the trickiest part of the whole job was when snapping the control module back into place on the steering wheel, ensuring all the wiring was routed properly so as not to interfere with getting the three rubber nubs back into their receptacles. I had interference behind the lower nub that took a second to get sorted.
    You also have to pay attention to the wiring as you slide the airbag module back in place so that the airbag module metal legs/extensions with the threaded hole slide exactly into place. Basically just don't force anything, if it isn't going easy pull it out and adjust wiring as needed.
    I followed the battery re-connect procedure, although I'll caution you need to read the whole WSM section on this as all the things you should do are not spelled out in chronological order or even on the same page.
    Altogether the project was a success, taking approximately 90 minutes but could easily be done in less than an hour next time now that I have done it once.
    My turn signal actuators are fully working again and thus far the start button has not had any intermittent issues like before, although it will take some more use of the car to confirm that the new NVO board fixed that issue also. Since the momentary switch is on the same board, I do suspect it is resolved.
    In studying the original NVO PCB I cannot readily see where it has failed by any visual indicators, but glad this new part from aliexpress got it fixed and saved me $$ thousands!
    Melvok likes this.
  19. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    Hi!
    Can anyone tell me what size/kind screws I need for this? There is also one in the upper right I forgot to circle which seems to be smaller. Got the car and it didn’t have any and don’t want this piece just hanging down.
  20. F485
    F485 Karting
    Oct 23, 2017
    173
    Abu Dhabi, UAE
    Fahad F458
    It looks similar size to the silver one. Try it and get similar if it fit
  21. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    Is there anything behind that could be damaged if the screw is too large?
  22. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    Also, am I missing fabric?
  23. 3POINT8
    3POINT8 F1 Veteran
    5,395
    Can’t wait for this thread
  24. Ivan Drago
    Jul 14, 2021
    1,309
    Midwest
    Ivan Drago
    LOL. Can’t tell if you don’t care about the thread, are making a joke about the time of there not being a thread yet, both, or being serious (doubtful)
