most powerful battery for the 456???? | FerrariChat
Discussion in '456/550/575' started by HKFerrariLlover, Feb 6, 2012.
  1. HKFerrariLlover
    HKFerrariLlover Rookie
    Oct 11, 2009
    37
    I just added a lot of new things to my stereo system and also installed HID headlights for my 456, I think I need a new battery that is more powerful. Anyone know what is the most powerful battery in the market right now that would fit? also where would I be able to find that in Hong Kong? As you all might know, the positive is on the left side for the 456, which is kinda hard to find.....please let me know if you have any idea......thanks in advance...
  2. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,166
    No clue where to find anything in Hong Kong, but here is a list of batteries available in the States. The original FIAMM battery is also on the list and I would look to see if Bosch's replacement batteries are available in Hong Kong.
    If you want the toughest battery, get an absorbed glass mat (AGM) battery like the Odyssey or Braille batteries in the document, or the Bosch S6001/S6008/096 AGM battery, which has the correct terminal layout.
    View attachment Ferrari Battery 02.doc
  3. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    HID lights normally consume less power than their equivalent halogen lights (35W vs. 55W).
    As for additional equipment, unless you installed something similar to what Pink Floyd used in Venice, you are probably well off with leaving it standard.
    Whether you need to change anything at all depends very much on what you put in and how you are using it. Assuming you only use the equipment when driving, it is not likely that the battery will fail you, but rather the alternator may not be able to keep it topped up in certain conditions.
    Get the current draw measured, or listen to the engine more often.
  4. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    If you have an additional 15mm of head space above the battery you can upgrade from a group 91 to a group 48 battery.
    There are anumber of excellent batteries in this size.
    Odyssey PC1220 CCA=680, reserve=135 min
    Exide Micro Hybrid EK700 CCA=760 (no reserve listed) Europe only
    East Penn Deka 9AGM48 CCA=760, reserve=120 min
  5. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    The biggest problem is "extra space": there isn't any.
