Motor mounts compressed to under 1mm of clearance after only 8 months/6K miles… | FerrariChat
Discussion in '360/430' started by Jaymac, Apr 1, 2024.
  1. Jaymac
    Jaymac Formula Junior
    970
    New Hampshire
    Jeremy McCurdy
    …but why?
    I replaced my ‘03 360’s motor mounts last year due to what I felt were excessive vibrations in the cabin.
    That was 8 months / and 6,000 miles ago. The cabin vibrations have recently returned. I can also see the exhaust tips on the drivers side vibrating much more than the passengers side. I checked them today, and the drivers side mount has less than 1mm clearance on the back side, and only just 2mm on the front. The passengers side has just over 2mm on the front, and just under 2mm on the back side. I’ll include pictures.
    What could cause mounts to collapse down this far so quickly? Everything was torqued correctly, but I can’t remember if I torqued once the engine and car were fully settled on the ground, but I *believe* I did.
    They were new OEM mounts from a forum supporter.
    What gives?
  2. Rifledriver
    37,089
    Torque of fasteners does not effect that.
    That gap was never meant to be a wear indicator.
    Are they cracked? Is there any issue of them performing their job?
    Ferrari flat crank motors as well as any flat crank V8 is famous for vibrations. Its why nearly no one uses a flat crank in a V8.
    one4torque and INRange like this.
  3. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    I can’t see any cracks. My basis for concern is that the cabin vibrations have returned. They dissipated when I first replaced them last July, but have since recently returned. That’s the only connection I can make. The trans bushing was also replaced with the 430 unit 2 years ago.
  4. Rifledriver
    37,089
    Vibrating Ferrari V8 engines are a no extra charge feature.
    Removing the central bolt and looking from the bottom for cracks in the rubber is the only way to determine engine mount condition.
  5. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    :D
    ItalGerBrit likes this.
  6. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    I had assumed that once the rubber blocks contacted the base plates, they would transmit extra vibrations through the chassis, and therefore, cabin.
  7. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    How is the transaxle bushing?
  8. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    Good. I replaced it in early 22
  9. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Let us know what might be causing the vibration when you find it. Maybe it is "normal" vibration and you just notice it more than others? Maybe ride in another 360 for comparison?
    Where did you get the gap measurement tool? I like that thing.
  10. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    At this point I don’t think I’ll dig any further, based on Brian’s input. I was basing it on internal cabin vibrations, which led me to replace them in the first place (on top of the age of the previous replacement, roughly 10 years). The vibrations quelled immediately upon the last replacement. Now they’re back, seemingly out of the blue. if anyone has any ideas, I’d gladly check!
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,901
    Central NJ
    Dominick
    Maybe try a throttle body relearn
    Disconnect battery .. wait 20 30 mins
    Start car and let it idle without touching the gas or turning on any electrically equipment until it gets warm then wait 10 mins running without touch a thing ..lights off etc
    Jaymac likes this.
  12. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I think the main enemy is heat but looks like you have stock headers.
  13. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,368
    Texas and Kaua’i
    Mikey
    Looks like Tubi headers to me.
  14. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    I had actually considered doing an ECU/TB reset, just to see. Easy enough and worth a shot.
    I didn’t think that would’ve been necessary at this time, because I just got the 360Trev tune about 4 months and 2,000 miles ago, which concluded with an ECU reset. There were no new vibrations present after the tune. They didn’t begin to present themselves until the last week or two. I did install new coils a month or two ago without doing a reset or tb relearn. I did them as part of the prerequisites Trev likes to have done when installing a tune: plugs, MAF’s, coils, primary 02’s. The coils were the only thing that didn’t arrive before the tune was installed. Perhaps not doing a relearn after the coils were installed affected the ECU’s? Either way, easy enough to do.
    flash32 likes this.
  15. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    Collegeboy is correct; Tubi heat-shielded headers, 200 cell sport cats, and Capristo Twin Sound cat-back. I always leave the engine lid open whenever I get home from a drive to dissipate heat, but not so much when parking out in public, for many obvious reasons.
  16. Tackleberry
    Tackleberry Formula Junior
    371
    United Kingdom
    Regardless of what Headers you have - stock or aftermarket - you still have an intense heat source right above a rubber based component, which is under a lot of stress. Inevitably the Mounts will succumb to that continual heat and sag.
    When I replaced my Mounts I made up some Heat Shields to at least afford some sort of barrier.
    After a couple of years use they seem to be holding out just fine, so the Shields are doing their thing.
    There is enough thread of the main bolt sticking past the nut to allow the fitment of the shield, a washer, and slim locking nut.
    Not the best pic, but this will give you an idea.........
  17. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    Smart. Very nice. Did you ever start a thread on making it? Which materials, etc?
    Tackleberry likes this.
  18. Tackleberry
    371
    United Kingdom
    Thank you.
    No I didn't ! To be honest I did them as an experiment - so they were only ever prototypes - to prove a theory. Of course at that stage never bothered with keeping any sort of record as they were completely hand made.
    The intention being if they did do their job - which clearly they have - I would them make some better quality ones and possibly sell them as a kit.
    I'll be checking them soon when I do my annual pre-season jobs, and if all looks good I'll revisit and look at a productionized version.
    Jaymac likes this.
  19. anotherred360
    anotherred360 Formula Junior
    Jan 10, 2015
    278
    The heat shield is a great idea given this appears to be creep-related settlement where high temps are a factor. I'm going to fab one up too.
    Jaymac likes this.
  20. windsock
    windsock Formula 3
    1,151
    Cam timing has a huge affect on idle quality. Were the cams timed, timed properly at the last service? If you have cam timing variations between banks you will never get it to idle as smooth as possible.
    tbakowsky likes this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,901
    Central NJ
    Dominick
    Based on what you just said .. definitely try it
    Jaymac likes this.
  22. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,422
    Santa Clarita, CA
    Can you post a link for the heat shielding pls.
  23. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    Can you post a link, or at least share the name of the heat shielding product you used? It looks like the same stuff used in the OEM 430 heat shielding I installed over the trans bushing when I replaced it.
  24. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    Agreed, and I’ve thought about that possibility too. The cams were timed at the second to last belt service, but this last belt service I did myself as a lock-and-swap. That was last May. The vibrations did not present themselves any more after the belts. It was running as nice and smoothly as before. The vibrations improved with the mount replacement in the July following, and have started to creep back over the last few weeks. I’ve often considered inquiring to local Indy’s about having the cams timed, but it’s pretty far down on my list. I pulled data from the Autel 2 months ago after seeing someone else’s post about cam timing. I’m the first to admit I’m out of my depth on this subject matter, but the figures I got were:
    “Camshaft and engine fase angle” were 650.688*C on one bank, and 651.594*C on the other bank.
    “Cross inlet/exhaust cross value” was 32*F for both banks.
    “Camshaft Cross Factor” was 0 for both.
    Again, I have little to no understanding of what these numbers translate to, expect for that I believe the fase angles are both low?
  25. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    I’ll be trying that on Friday as soon as I’m done with work for the week!
