Motor Mounts | FerrariChat
Motor Mounts
Discussion in '456/550/575' started by jaticker, Feb 9, 2011.
  1. jaticker
    jaticker Formula Junior
    Oct 27, 2007
    251
    tampa
    John Annis
    My 550 is a 99. Should the moter mount be checked ? I've seen several post mentioned the factory did a recall on mounts. Is it a big effort to check ?
  2. Rifledriver
    37,192
    There is no recall on motor mounts.
    Does your mechanic look at anything when he services the car?
  3. edeo
    edeo Karting
    Apr 6, 2006
    76
    There are several older threads on the 550 engine mounts. I had a '99 550 and had them replaced. The common fix was to install the newer 575 mounts. Cost was around $800 IIRC. Does your engine contact the hood liner?
  4. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #4 toggie, Feb 9, 2011
    One way is to put the car on a lift and remove the bottom cover from the front half of the car.
    This enables you to get a good view of the motor mounts from underneath.
    You might be able to see them through the holes using a flashlight.
    Below is a picture of one of my failed motor mounts (picture was taken a few years ago).
    The bottom washer ring should not be hanging down like that.
    My understanding is that it should be up tight up against the bottom of the rubber part of the mount.
    It is sagging because the motor has dug into the top of the rubber part of the mount over time and now the engine is sagging on that side.
    The 575 motor mount has another metal plate on the top of it which is what keeps the motor from digging into the rubber part.
    It is a better design and solves this problem.
    550's should have their motor mounts replaced with 575 ones once sagging starts to appear.
    My understanding is one of the real dangers of sagging motor mounts is it exposes an oil line on the bottom of the engine.
    It can sag low enough that it may scrape on something while going down the road.
    If it hits road debris then all the oil can drain quickly out of the engine and the engine will have permanent major damage in a matter of a few minutes time.
    So, given the cost of a replacement engine, upgrading the motor mounts is a good idea.
  5. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Has anyone heard of the mounts failing on the 456M? I believe they use the same part #.
  6. Rifledriver
    37,192
    #6 Rifledriver, Feb 9, 2011
    They used the same mounts and they are the reason Ferrari ran out of new 456 motors many years ago.
    These are the new updated mounts. We replace them with some regularity. They are better but as you can see they are not a fix.
  7. fatbillybob
    Aug 10, 2002
    29,114
    socal
    Probably a Porsche mechanic...
  8. fatbillybob
    Aug 10, 2002
    29,114
    socal
    Toggie,
    Sell those old MM's on Ebay as Ferrari race parts. "ESpecial ferrari 550 1" lower motor mounts. Lower your car's CG and go faster!"
  9. alex550575430
    alex550575430 Formula Junior
    Jun 21, 2009
    427
    LOS ANGELES, CA
    LIN ALEX
    Hahahahaha..... there you go......
    Alex
  10. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
  11. jaticker
    Oct 27, 2007
    251
    tampa
    John Annis
    I've only had the car for 3 months. I haven't felt the need for any inspection till now. Going in tomorrow.
  12. drrob
    drrob Rookie
    Apr 11, 2009
    18
    North Alabama
    FoA is quoting me $1850 (8.0 hrs labor) for a 2000 550. Does this sound about right?
    RRS
  13. deanhalter
    deanhalter Formula Junior
    Dec 27, 2008
    357
    Norco, CA
    Dean Halter
    #13 deanhalter, Feb 26, 2011
    I just did mine and it was a pain. This was a first time through for me and 8 hours seems a bit high, though there were times when I could have used a helper...
    After having done this job - I think I would pay that to have it done by someone else...
  14. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Mine's in the shop at this moment and motor mounts are one of the now necessary items on the to-do sheet.
  15. Zedtt
    Zedtt Formula Junior
    May 29, 2005
    381
    Southern California
    Terry
    I was recently informed by a technician at a dealership service
    facility that sagging motor mounts will cause the engine
    to drop and will cause interference with steering that
    one can feel. Marks on the hood pad more likely to be caused
    by a sagging pad. A sagging motor mount will result in the
    engine moving away from, not closer to, the pad.
    Zed
  16. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Ask that technician about torque reaction and it's effect on the motor when the mounts not only sag but allow upward movement of the motor.
  17. tazandjan
    39,238
    Dave- The check we used to make for a broken motor mount was to hold the brake and rev the engine just slightly. The engine would rear up where it was not constrained. Pretty easy to spot on an American V8 with and automatic. Probably a bit more subtle on a V12 with a loose mount.
    Taz
    Terry Phillips
  18. deanhalter
    Dec 27, 2008
    357
    Norco, CA
    Dean Halter
    #18 deanhalter, Feb 27, 2011
    I did not feel anything in the steering, and mine were toast. Alternator was hitting the anti-roll bar and the oil sump was contacting the fluid return line from the steering rack. Picture below is with that line removed from the rack - the bolts were removed from the rack to move it forward to access the mount bolt from below.
  19. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Back in the early 60s I once hooked up an old fuel gauge sender to the top of the valve cover with a rod on a MGA. I had a switch where I could switch between senders. One way read the tank, the other way read how far the motor reacted to torque,
    I never got much more that a quarter tank of torque though :)
  20. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    #20 2000 456M, Feb 27, 2011
    My independent mechanic, ex-Ferrari dealer tech, quoted me $900, including the mounts. I don't know if there are reasons why 550 and 456M prices might differ, but maybe someone can chime in.
  21. tazandjan
    39,238
    Allan- $1800 did sound excessive, but one of the mounts, I forget which, is a real pain to reach and requires removing quite a bit of stuff on a Maranello. Not sure about a 456/M.
    This is the kind of stuff you would like to hear from Brian, but I think he hates to get into prices too much.
    Taz
    Terry Phillips
  22. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I was a bit uneasy quoting my mechanic's price. He's a great guy and it's possible he was giving me a break on the cost of the work, maybe because I'm having a number of other items done at the same time.
  23. 308 GTB
    308 GTB F1 World Champ
    11,748
    New Jersey
    Barry Wolinsky
    The driver's side.
  24. tazandjan
    39,238
    Brian- If I paid shipping, would you send me a set of the 575M motor mounts you have removed? I will ask Pfadt if they could be rebuilt or something better produced for a reasonable price. Their C5/C6 mounts are $250 a pair, way better than $349 each for Ferrari mounts.
    Might also be something Paul Hill might be willing to tackle.
    Taz
    Terry Phillips
