motor oil for Testarossa | FerrariChat
Discussion in 'Technical Q&A' started by Rene, Jan 5, 2004.
  1. Rene
    Rene Formula 3
    2,164
    London
    René
    I have an '87 TR and have been using engine oils closest to the recommended Agip 10W50. In fact this particular oil is all but impossible to find, but presumably progress in oil development means that a variety of substitutes is possible.
    Basically I have two questions: first, which oil would you recommend and, if this is not an all-synhetic oil, is there any advantage to using the latter anyway ?
  2. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    My TR went 115k miles on Castrol GTX.
  3. Steve Magnusson
    25,261
    Rene -- What is your reference for 10W50? (My TR OMs call for 10W40). I also have just been using Castrol GTX 10W40.
  4. kdross
    kdross Formula Junior
    887
    NJ
    Ken
    Rene:
    I have a 1985 Ferrari 308QV and a 1990 Alfa Spider. Both cars require Agip 10W-50 as per the owners manuals and stickers in the engine compartment. Agip has not made 10W-50 for serveral years. They now make 10W-40 SINT 2000 or (SYNT 2000 - same stuff but one is made in Europe and one is made in the USA) and this is the oil recommended by Agip, my local Ferrari dealer, and my mechanic. The stuff is hard to find, so you may want to call Agip (www.americanagip.com) and have them ship you several cases.
    Ken
  5. jw6513
    jw6513 Karting
    Nov 24, 2003
    50
    Arizona
    Jim Whitney
    I wouldn't consider anything but synthetic, and Castrol now makes a 5W50, which I like as the lower starting weight provides better protection at startup. I use synthetic in the transaxle of my 308 as well.
  6. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Here in the UK we use Shell Helix Ultra 5W/40, this has been specially "blended" by Shell for Ferrari
    MW
  7. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    If you have any extreme use, and/or very high ambient temperatures, use a 10w60.
    Malcolm, the 360 Challenges turn the shell to gnats pi55 here in Oz. The datalogging shows spikes of huge oil temp and pressure loss using shell.
    Michelotto use 10w60 in the 360 GT cars, in all conditions.
    I find Castrol R synthetic 10w60 bombproof in all cases, but pricy.
  8. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Phil,
    To clarify we only use the Shell Helux 5W/40 in road cars, we still use Shell in our Challange cars, it's the same viscocity as you are useing being 10W/60
    MW
  9. Rene
    Rene Formula 3
    2,164
    London
    René
    I am very, very grateful for your replies and for the speed with which you answered too. Perhaps Ferrari buffs and speed go hand in hand, or more likely Ferrari chatters are simply the best.
    I live in London, so obtaining Castrol or Shell to the specifications you suggest, Napolis, jw6513 and Ferrari_uk_tech, will be no problem. Kdross, I spent the Christmas holidays in Italy where every other petrol station seemed to be Agip. I did wonder whether buying several cans of oil might be a good idea, but concluded that at airport security I was more likely to be allowed to board a flight with olive oil or grappa.
    I don't find it easy to read the dipstick, which I was told should not be done from cold, the problem being that the reading is taken from a dry sump. Looking at the manual, it suggests letting the engine idle "for a few minutes", stopping it and taking a reading "after a few seconds". Whereupon, instead of getting a zero reading when the car has been unused for several days, I seem to get a dipstick with oil all the way up to the top -even after wiping it ! My solution has been to follow, ever faithfully, the blessed manual and to top up with a litre of oil every 5 or 600 miles.
    Since aquiring the car last August I have done 6000 miles without problems, although at the end of a long run in hot weather (upwards of 500 miles across European motorways), there is sometimes a high-pitched whine emanating fromt the motor...
  10. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    I would not just add a liter every 500-600 miles, always check first as every engine is different than the manual. I would suggest waiting a minute or so after shut down and read the dipstick
  11. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Rene - be carefull how long you wait after stopping the engine before checking the oil level, the longer you wait the more chance you have of overfilling - the best way is to check the level as soon as you have stopped the engine.
    MW
  12. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    A tip=If you aren't used to watching your oil pressure guage, start doing it. When mine is properly filled, it goes directly to the TDC of the pressure guage and doesn't drop at idle but a hair. You can tell if your oil is low or needs checking. Then you don't have to really worry about letting it get too low.
  13. f355spider
    f355spider F1 World Champ
    17,951
    Ferrari changes the spec on the recommended oil based on their favored supplier, and what that supplier makes. There is a service bulletin dated 6-15-88 #00-25 stating that the new preferred oil is now Agip Sint 2000 10w-40 and that the recommendation switched, based on 10w-50 no longer being made by Agip.
    I am certain if you were to ask, they would recommend that you use the current Shell Helix 5w-40 synthetic, which is likely to be fully compatible with you car.
    Personally, I would just find something that suits you, they are all probably fine. Mobil 1 5w-40 or 0w-40 is probably much cheaper than the Shell Helix, and just as good, if not better.
    Check the threads on oil pressure and oil "weight" both on the new and old site. Great info by Ali Haas on the subject.
  14. kdross
    887
    NJ
    Ken
    Dave:
    Where did you get the info regarding the service bulletin? Is there a source to obtain the service bulletins of Ferraris either on the Internet or privately?
    Ken
  15. f355spider
    17,951
    Ken,
    go here: http://ferrari.stevejenkins.com/books/
    I got the info from the link for the 328 tech specs, etc...it has some of the relevant TSB and service bulletins and some apply to other models of Ferraris at the time. I know of no comprehensive list of TSB's or serivce bulletins available any where specific on the net or available for purchase.
  16. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,598
    Pacific NW
    Anthony C.
    I agree with Dave and that is my understanding as well. I believe Ferrari went from Agip to Shell in 1996, for both their F1 team and road cars. My understanding is that as long as you stay within the same oil weight recommended for your car and for the climate you are in, you will be fine. I would however, use synethics oil instead of conventional oil as they tend to provide better range of protection.
