Motor Oil Mobil 1 ? | FerrariChat
Motor Oil Mobil 1 ?
Discussion in 'Canada' started by MS250, Apr 13, 2008.
  1. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,577
    Avvocato
    Anyone able to get there hands on Mobil 1 15/50 Syn ?
    Been to the usual suspects, CDN tire, WalMart, Partsource, and even the local Lubes, but they dont have it.
    Anyone know where to find it ?
    Thanks.
  2. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    is that what you use in your cars? I have seen 5/50-is that any good for you?
  3. wheredidtheygo
    wheredidtheygo Karting
    Jan 23, 2006
    181
    Canada
    Michael C.
    Ask Zahir.. If he cant get it then might be hard pressed..
  4. arium
    arium Karting
    Jun 16, 2005
    126
    Port Coquitlam, B.C.
    Steve H
    Hate to tell you but the Mobil1 "performance driving formula" has been reformulated. 15/50 is no longer available and has not been on most store shelves for the better part of a year now. The new formulation is the 5/50 mix.
    The experts will tell you that this product will still give you the protection of the 50W at the higher temp range but will give you the lowest friction 5W at the lower temp range. My Lotus 910 engine rattles like heck with this stuff in it.
    I'm not sure if you'd even want to be sourcing outdated product to satisfy your viscosity requirements. Old oil apparently can vary greatly from rated specs with age. There's also been a very heated online discussion about adverse reactions with valves/seals etc with the new additive package that goes with this new oil.
    I'm seriously thinking about switching back to dino oil.
    Steve
  5. MS250
    Dec 10, 2003
    26,577
    Avvocato
    Steve, i heard the 15/50 was to be back on the shelf....is that BS now then ?
    I was thinking of going 5w/50...ive had great success with the Mobil 1 product, would hate to switch again....you dont like the 5/50 then ?
  6. goezfaster
    goezfaster Karting
    Sep 18, 2007
    234
    Today?
    Earnest
    I just bought some on Monday of this week at the local NAPA parts store. However, having said that I am in Michigan this week.
  7. MS250
    Dec 10, 2003
    26,577
    Avvocato
    you bought the 15/50 Mobil 1 ? Do you know if its still around as a common item ?
    If i cant find it, i think im going 10W/60 Agip (Syn)....but really dont want to.
  8. arium
    arium Karting
    Jun 16, 2005
    126
    Steve H
    A quick look through the Canadian website only shows 5W50 Mobil1. Zipped through to Mobil1.com and low and behold; Back by popular demand 15W50. Pigs do fly I guess.
    Heres a link http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_15W-50_.aspx
    Hopefully it does make its way back here soon as I believe that the 5W50 doesn't provide the same anti wear for valvetrain as the original does. Especially on a cold start. Lots of buzz about leaking seals as well but no solid proof there either.
    Steve
  9. MS250
    Dec 10, 2003
    26,577
    Avvocato
    Thanks Steve, i called Mr Lube. Seems that they are able to order it and get it...apperently special order item, said they ordered it and i should have it for this friday as per there delivery. Lets see if they pull through.
    Thanks for the link !
  10. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Rick I run 0w40 Mobil 1 in my 308 (available at Partsource) and think it is great. No leaks, tons of oil pressure, the car cranks with more gusto and revs more freely. I would NEVER go back to 20W50 oil. Ignore the owners manual, it was written 30 years ago and oil technology is on a different planet since then.
  11. Skipro
    Skipro Karting
    Aug 14, 2006
    57
    Que,Can//Naples,FL
    Richard
    I've been using Mobil1 5W50 in my 92' 348tb for 2 years now with no issues. Ideally I'd prefer 15W50. I have my oil (gearbox & engine) analysed by Blackstone Labs annually and the viscosity of my drained Mobil1 5W50 engine oil falls in the middle of the range of where it should be so I'm not worried about whether it's 5W or 15W.
    Ref: www.blackstone-labs.com
  12. MS250
    Dec 10, 2003
    26,577
    Avvocato
    Robbie, Ciao !! I was thinking of going 10W60...on both...but i think i have found the 15/50....i personally dont use the owners manual in either of the cars, but wish to standardize on something for both.....
  13. PapaiK
    PapaiK Formula Junior
    Mar 5, 2005
    871
    Ottawa, Canada
    Kyle
    I bought a 4.4L jug of Mobile 1 5w50 a couple weeks ago at crappy tire.
  14. imcarthur
    imcarthur Formula Junior
    Nov 15, 2004
    396
    Toronto
    Ian
    Just an FYI . . . oils for older cars >20 yrs
    Oil formulations change. Olders cars like a formulation that includes Zn etc additives that are now missing from most modern oils. Castrol is no longer the old Castrol, Kendall, Mobile 1 have all changed in the last several years etc etc. There are threads after threads about oil in the older Porsche groups. Particularily in boxer type engines. I don't know Ferrari engines but here is a thread that is worth a read.
    http://forums.pelicanparts.com/showthread.php?t=367300
    The thread is 42 pages long (and counting), but the poster sums it up in the 1st post. Brad Penn Racing Oil is the best 20W-50 currently available.
    fwiw
    Ian
  15. imcarthur
    Nov 15, 2004
    396
    Toronto
    Ian
    #15 imcarthur, Apr 17, 2008
    And post # 684 has these:
    "Here we go. I've tabulated the averages from every pull and it looks like Brad Penn and Swepco were basically identical in performance, but the Swepco edged out just by a hair with a lower BSFC. . . . Just for identification, Swepco 15w40 is #1, Brad Penn 20w50 is #4, Royal Purple Max Cycle 20w50 is #5, and #9 and #11 are Mobil 1 4T 10w40 and Mobil 1 V-Twin 20w50 respectively.
    #12 and 16 were Mobil 1 0w20 and an unspecified racing 0w20 oil, as we were wondering what effect viscosity would have on our testing. By no means would we recommend runnning anything that light ever!" . . . by Charles Navarro
