Motor Paint? | FerrariChat
Motor Paint?
Discussion in 'Vintage (thru 365 GTC4)' started by dgunn365, Aug 28, 2022.
  1. dgunn365
    dgunn365 Formula Junior
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    Has there been a thread on how Daytona motors were painted; and with what?
    Ours shows clear signs that parts of it were brush painted. Typical??
    Any help or leads will be appreciated as we are at that stage.
  2. V12addict
    V12addict Formula Junior
    Jan 2, 2004
    293
    Are you talking about the engine castings ? I am not sure if they were painted on the outside from the factory. I have painted some engine parts with Dupli-Color enamel with ceramic with great results. They even have a color called aluminum cast. However the latest and greatest in my opinion the vapor blasting. It give a beautiful clean result that looks amazing.
    Bertocchi likes this.
  3. dgunn365
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    Yes, the castings. Thanks for the input. We do know about 'aluminum cast' but vapor blast is a new idea.
    V12addict likes this.
  4. TTR
    TTR F1 Veteran
    5,891
    Riverside, CA
    Timo
    My (limited) experience and observations have made me believe that many, maybe most or perhaps even all Daytona engines (block, heads, timing chest & sumps) were externally painted by the factory, although afforded efforts and results were quite rudimentary at best, nothing like commonly seen in more recently rebuilt/restored examples.
    daytonaman and V12addict like this.
  5. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,038
    Timo is correct, Daytona engines were painted silver by the factory.
    daytonaman, V12addict and TTR like this.
  6. V12addict
    Jan 2, 2004
    293
    Thank you Timo and Dyke, is that because the older aluminum castings were porous or is was it more for aesthetic reasons.
  7. TTR
    TTR F1 Veteran
    5,891
    Riverside, CA
    Timo
    I believe castings (of vintage Ferraris) are/were quite good and the external painting, however rudimentary, was mainly for aesthetics.
    OTOH, the internal coating/painting was likely done, I believe, to seal any casting sand residue potentially still stuck in the pours from getting loose and mixed with the oil.
    I believe all the above applies to transaxle housings also, but as I’ve said before I wasn’t there when these cars or their components were made, so not able to fully confirm.
    pshoejberg and V12addict like this.
  8. Admiral Goodwrench
    Admiral Goodwrench Formula Junior
    Mar 2, 2005
    766
    Santa Fe, New Mexico
    Robert Phillips
    What I can tell you is that whether it is light sand blast, soda blast or vapor blast, the resulting bare casting surface will very quickly show any oily finger or hand print. Just another reason for the paint.
    Best regards,
    Robert
    Tegethoff, pshoejberg and V12addict like this.
  9. V12addict
    Jan 2, 2004
    293
    True Admiral, i agree. Plus bare aluminum can eventually tarnish and oxidize depending on what kind of climate it resides in.
  10. V12addict
    Jan 2, 2004
    293
    Thank you Timo, yes now i remember my wonderful friend the late Allen Bishop helped me use the green zinc chromate on the inside of the valve covers when we were doing my 365 GT engine. Also if it is of any value, i painted the valve covers of my other Italian with the Dupli-color high temp paint with ceramic previously Image Unavailable, Please Login mentioned.
  11. dgunn365
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    I appreciate all the input and, I believe, can assume the factory did paint the castings a 'silvery' color; and, perhaps in the early Daytona days, used a brush to do so!?
  12. dgunn365
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    Do we also conclude that the inside of the cam covers were painted with zinc chromate?
  13. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    I was told to paint the inside of my cam covers with a thin coating of zinc chromate as a primer followed a good coating of glyptal paint.
    The cam cover casting are quite porous. Without this painting, oil will seep through them and ruin the outside back wrinkle.
    Bowzer, V12addict and turbo-joe like this.
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,531
    romano schwabel
    not only the cam covers
    Tegethoff likes this.
  15. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    I agree. I think that the whole block and sump are porous.
    Tegethoff and turbo-joe like this.
  16. turbo-joe
    Apr 6, 2008
    9,531
    romano schwabel
    absolutely true, like a sponge :(
  17. dgunn365
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    Thanks, looks like we need to do it where we have access.
  18. TTR
    TTR F1 Veteran
    5,891
    Riverside, CA
    Timo
    #18 TTR, Sep 1, 2022
    I haven't seen that on Daytona engine castings, but accept both of you having more experience than I.
  19. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
  20. Tegethoff
    Tegethoff Formula Junior
    Jul 19, 2014
    301
    Los Feliz
    Adam
    From what I have seen, by the early 1970s, casting quality was significantly improved from the earlier blocks and heads.
    The lack of production volume and independent nature of Ferrari before Fiat got involved is readily apparent in porosity and other casting defects. I would love to know the extent of technical assistance in the foundry provided by Fiat.
    readplays likes this.
  21. dgunn365
    Dec 15, 2006
    251
    New London, NH
    David Gunn
    Quite a project Nuvolari; thank you for passing on the details.
  22. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    342
    Scottsdale, AZ
    Jim
    Most all of the engine parts were painted, but not the distributors. I like the Harley engine paint; great quality.
    enio45 likes this.
  23. GSJFerrari
    GSJFerrari Formula Junior
    383
    Stuart, FL
    Greg Jones
    Greg uses Glasurit with fantastic results, 55-m 99/09 "Fine Aluminum" and 923-58 "Urethane Acrylic Clear Matte." He mixes the fine silver into the matte clear and it gives a very resilient finish that doesn't look like it has been painted and the castings look natural. You can see the contrast between the freshly restored and unpainted distributors against the painted angle drives.
    -Prescott @ GSJFerrari
    Modena Motori and V12addict like this.
