Motronic 2.7 self diagnostics | FerrariChat
Discussion in '456/550/575' started by Dr1ve, Aug 27, 2025 at 10:17 AM.
  1. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    31
    Norway
    Ole-Jakob Nilsen
    Hi all!
    I would like to flash some codes in on the dashboard, but my 1995 456 GT does not have the diagnostic push button on the ECU.
    There are 3 plugs coming out from the main loom, a 3-connector which I presume is for the SD-1 and two single connectors with a blue and black wire.
    Any knowledge on which wire I should short to ground - preferably without frying the ecu?
  2. Qavion
    Qavion F1 World Champ
    14,432
    Ian Riddell
    I only have one wiring diagram for the 456GT (2.7), and that is the Left Bank Engine diagram. It shows the following:
    HN = grey with black stripe
    N = Black
    HR = Grey with red stripe
    Your colours look different.
    On the Ferrari 348, I have these colours:
    N = Black
    HM = Grey with brown stripe.
    That seems to be a better match. Anyway, in either case, just short out the black and grey/red as per the test procedure.
    In the diagram, the 456GT blue and black wires are labelled "For excluding idle speed control", whatever that means. They are joined together to produce that effect, but I guess they are not normally joined.
    flash32 likes this.
  3. Qavion
    14,432
    Ian Riddell
    Assuming that wire on the right is grey/red...
    Make sure that you have bulbs in the Check Engine lights. I heard that some Euro cars don't have bulbs.
    flash32 likes this.
  4. Qavion
    14,432
    Ian Riddell
    flash32 likes this.
  5. Dr1ve
    Dr1ve Rookie
    Feb 2, 2022
    31
    Norway
    Ole-Jakob Nilsen
    Thanks!
    The 3-pin connector has the correct wires - grey/red and black.
    I got the correct bulbs fitted in the binnacle. I'll have a go flashing codes later today!
